CM5908 Light Bulbs?
  • McGyver
    • 4636
    CM5908 Light Bulbs?
    I took the volume/scan knob PCB out of my radio to clean in isopropyl. While it was out, I noticed that the illumination bulb was a little crusty/burnt. As I was scraping it, one of the leads broke.
    Does anyone have a technical manual for this radio? Are these the correct bulbs?
  • midnight_marauder
    • Sep 2019
    • 83
    Did you ever go about replacing the bulbs? How’d it go? About to do it myself to a CM5908.
    📸 @joyfilledpursuit
    📖 John 3:16-18
    • McGyver
      • 4636
      These bulbs are much smaller than the bulb behind the volume knob. I believe the bulbs I ordered are for back lighting the LCD and the buttons. I still used one of these bulbs for the volume knob, but it's definitely not the same as the factory bulb.
      • midnight_marauder
        • Sep 2019
        • 83
        How was desoldering and resoldering? The solder joints for the bulbs look super small, I tried removing one but couldn’t get all the solder joint off and I was beginning to worry I was going to fry the board if I heated any more.
        📸 @joyfilledpursuit
        📖 John 3:16-18
        • earthwormjim
          • Jul 2014
          • 434
          Can you take a picture? What tools are you using? At the very least you will need a solder sucker and probably solder wick braid to get the old solder off.
          • McGyver
            • 4636
            I just used a solder wick, which makes things easier than trying to use a solder sucker. It takes some patience, but it's doable.
            • earthwormjim
              • Jul 2014
              • 434
              A flux pen or wick with flux loaded into it can help a lot, especially on these really old and oxidized solder joints.
