DVC sub wiring
  • Rob
    • 8166
    DVC sub wiring
    I found a JL 10w3 for sale cheap locally, and I'm wondering how I could wire it up since its DVC with dual 4ohm VCs. Is there a way that I can run a single 4ohm channel to the sub? or will I need to do something else?
    BEERTECH
  • Brew
    • 3060
    AFAIK, no.
    My Alpine Type-R is a dual voice coil sub also, and there was no wiring descriptions in the manual that would give it 4 ohms. I'm pretty sure the only way to get 4 ohms is to have two dual 4 ohm coil subs. I just run mine at 2 ohms.
    No problems so far...
    '91 318is
    • Mystikal
      Wheel Fitment Expert
      • 9602
      I don't think you can run just one voice coil. Doesn't make sense to me, they would collide.
      Brew, how do you like the Type-R? What size? I'm VERY likely going to grab one in the near future to replace my PG.
      • Brew
        • 3060
        Its a 10".
        I like the sub a lot. It is clean even at very loud volumes, and seems to be very well made.
        I got mine off of ebay pretty cheap. IIRC, it was about 120 bux brand new in the original packaging.
        '91 318is
        • BMW BMXER
          • 2325
          Running a DVC sub on one VC voids the warrenty.
          Sold it.
          • kencopperwheat
            King of Kegstands
            • 14396
            You can only wire the two VCs in parallel or series, which would yield a 2 ohm and 8 ohm load, respectively. If your amp can handle it, run it 2 ohms. But remember that if you bridge your amp you're effectively cutting the resistance in half again and it would be a 1 ohm load. If you bridge a 2-channel amp to an 8-ohm speaker (a DVC wired in series) it will yield a 4 ohm load.
            Originally posted by Gruelius
            • Beej '86 325es
              • 2639
              Haha, I did that on my old Infinity Beta sub and Orion Cobalt amp. Melted the fuse to the fuse holder. Eventually blew the whole rubber surround right off the cone. The amp still worked fine with a jumper wire in the fuse holder.
              -Brandon
              '86 325es S50
              '12 VW GTI Autobahn DSG
              '03 540i M-Sport (sold)
              '08 Jeep SRT-8 (sold)
              For sale:
              S50 TMS chip for Schricks
              • Rob
                • 8166
                so i'd need two channels for the sub (a 4 channel amp bridged in my case I guess)
                BEERTECH
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  No, only one channel. You cant run the voice coils in stereo.
                  • Rob
                    • 8166
                    well i guess i shouldnt get the sub since i'm not going to shell out the cash for some huge expensive sub amp. oh well.
                    BEERTECH
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      You can bridge two channels of the 4 to the sub and use the other two for mids.
                      • Rob
                        • 8166
                        what about dual 2 ohm?
                        BEERTECH
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          Dual 2 ohm voice coils? You could either wire it to produce a 1 or 4 ohm load.
                          • Rob
                            • 8166
                            that would be ideal for my purpuses then i guess
                            BEERTECH
                            • Bryson
                              • 1490
                              get a dual 2, i'm trading in my dual 4 10w3v2 this week for a dual 2 to run at 4 ohms off of a bridged amp.
                              you can also get a monoblock for the dual 4 ohm, that should be stable at 2 ohms
