MS w/ multiple coils
  • asubimmer
    • 6482
    I'm have MS1 v3.0 for my car and I converted my stock coil pack on my M42 to a COP like a m50 a while ago. I'm trying to figure out how to install MS w/ multiple coils and I'm not really getting anywhere
  • 2002maniac
    • 4260
    megasquirt.info
    it's all in there. Start reading ;)
    • MarshallM
      • Feb 2007
      • 229
      E30tech.com has a megasquirt section. That would provide more answers.
      • backtrail69
        • Jul 2005
        • 4471
        Most of the guys run Wasted Spark or Single Coil setups with MS. I am working on my single coil setup currently. Seriously check out the tech, many very knowledgeable people there willing to help newbs like you and me.
        :: PNW Crew ::
        '87 325 4dr, '74 2002
        • 2002maniac
          • 4260
          The m42 has no distributor so you need multiple coils.
          • MarshallM
            • Feb 2007
            • 229
            I dont think MS can handle 6 coils. Im pretty sure there is only enough room for 4 drivers. thats would get waste spark for a v8 but not enough for 6 coils. Basically if MS can handle 6 coil drivers then COP shouldnt be a problem. email diyautotune.com and ask they should have an answer for you.
            • backtrail69
              • Jul 2005
              • 4471
              I knew that, but I Know MS has one ignitor onboard, so you would need to add an additional 3 ignitors. Does the M42 use the same 60-2 VR wheel? If so RPM input will be easy and proven. Look at Matt's wiring diagram on e30tech:
              I would assume the procedure would be the same just with an additional igniter.
              :: PNW Crew ::
