Turn signals not working
  • *R*
    • 230
    Yesterday my turn signals were working just fine. but today, theyre not blinking and you cant hear the clicking inside. i looked at the fuse and it wasnt blown, but i replaced it just incase and it still didnt work. How do i fix it?
    http://www.collegehumor.com/video:1726949
    Originally posted by 92 mtechnic cabrio
    gross, I bet that has an offset so positive it could prove to eliminate all emo feelings
  • NC325iC
    • Mar 2004
    • 6565
    sounds like the relay is dead
    • *R*
      • 230
      do i just go buy a new one?
      • hella::tuned
        • Oct 2007
        • 7
        hade some of the wires on the back of the turn signal housings come out and made them go dead
        • jerods87e30
          • Jun 2007
          • 226
          You may want to get in contact with Funkmasta because he is currently selling all sorts of switches. It's likely that either your relay is dead, or your switch has gone bad, which explains the absence of clicks noises and lights. I'd check your relay first, then replace the switch.
          • *R*
            • 230
            the weird thing is, they started working again.
            • AndrewBird
              The Mad Scientist
              • 11898
              When you guys say relay, do you mean flasher? Because I don't think there is a relay in the turn signal wiring.
              • StereoInstaller1
                GAS
                • 22679
                +1
                Closing SOON!
                Thanks for 10 years of fun!
                • DrMcDave
                  • 1793
                  hazard light switch is prob going.
                  • pawi30
                    • May 2007
                    • 1091
                    i have the same prob...they were working..i lost my lens caps..some rain got in..the next day they didnt work..12 hrs later they worked..then finally they just stopped and i had to hit the bottom of the steering wheeleverytime i wanted to use them..and now they are just toast..where is the relay..is it easy to fix?
                    Originally Said by Bob Marley
                    "BMW make pure trouble!"
                    • Van Westervelt
                      • 9365
                      Under the lower panel of the steering column. Pull it lay on your back, and it will be right in front of your ugly ass face.
                      • DEV0 E30
                        • Oct 2004
                        • 8879
                        Or not connected.
                        • Spec
                          • Dec 2005
                          • 320
                          I have a similar problem.
                          My left front turn signal isn't connected so I've had the quick flashing left signal for a while. When I installed my euro elips, all of a sudden the turn signal stopped working. It still clicks fast and blinks in the cabin, but no blinking in the back. Lightbulb looks fine but I'm going to replace it anyhow. Haven't checked fuses will tonight. Just discovered this a couple days ago.
                          1991 BMW E30 318i sedan
                          2005 Kawasaki 636cc ZX6-R
                          PNWRiders.com
