Premium sound wiring
  • SamE30e
    • Sep 2007
    • 4319
    Alright, so I got a new headunit and ran new wires to the front speakers, and I don't really want to run new wire to the back for the rears.
    I have a 87 325e with the premium sound setup, there is a factory amp in the trunk and it has the fader above the radio. I pretty much want to use existing wires to get to the rears if someone could help that'd be awesome
    Thanks.
    1985 325e 2.8 Turbo VEMS
  • Jordan
    • 12911
    Run new wire.
    https://mtechniqueabs.com/
    • DaveSmed
      • Apr 2007
      • 1407
      Simple enough. Cut the fader plug off, and chuck it and the solid blue and solid yellow wire in the trash.
      Connect the yellow/black wire to the green/black wire from the headunit.
      Connect the yellow/red wire to the green wire from the headunit.
      Connect the blue/black wire to the purple/black wire from the headunit.
      Connect the blue/red wire to the purple wire from the headunit.
      Now go to the connector for the factory amp, unplug it and cut these wires:
      Two black/brown wires
      Black/purple
      Black/white
      Yellow/black
      Yellow/red
      Blue/black
      Blue/red
      Connect the black/purple to yellow/black.
      Connect the black/white to blue/red.
      Now temporarily connect a black/brown wire to the yellow/red wire and turn on the headunit. If sound comes from the left speaker, make the connection permanent, and connect the other black/brown wire to the blue/black wire. If there is no sound, reverse the black/brown wires.
      -Dave
      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
      Need some help figuring out the ETM?
      • SamE30e
        • Sep 2007
        • 4319
        Black/purple
        Black/white
        Yellow/black
        Yellow/red
        Blue/black
        Blue/red
        Yea I tried that myself before you posted it using diagrams. I just said fuck it and went and bought 60' of wire, connectors and heat shrink tube. I lost the sound from my tweeters but oh well I'll wire em up later.
