Non-E30 Audio Question (E36 BMW)
  • UNHCLL
    • 8789
    Can you install a headunit into an e36 without rewiring the whole car like you have to do in an E30?
    I'd like to get my sister a CD player for her car, and want to be able to plug & play, even if it just means getting an install adapter/kit.
    TIA,
    Chris
    Below the radar...
  • Mtriple
    • 3139
    pity reply...
    As for your question, I had no problem wiring an Alpine 7894 into the HK system on my 96 M3. Just wired it up to the aftermarket harness and plugged it right in. Sounded great!
    Originally posted by Simon S
    • smonkbmw
      Professor
      • Jun 2006
      • 4549
      +1. just need a harness adapter. getting the "cage" to lock in is a pain in the ass. wait, i think it needs a antenna adapter also.
      • StereoInstaller1
        GAS
        • 22679
        Chris, there are 2 different wiring harnesses for E36. Early (pre '96, IIRC) uses the same antenna as a normal car, later cars use a "Euro" antenna adapter.
        I have only seen one E36 without an amp, that was a '93 318.
        The stock E36 amplifier/speaker combo is an amazingly good sounding setup with the exception of bass, of which it has none. I HIGHLY recommend choosing a deck with high-pass filters so it is easier to subwoof.
        Quick easy job for a deck install in an E36.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • UNHCLL
          • 8789
          Cool, thank you guys.
          Sister is getting the headunit only. No other items will go in her car, she's dangerous enough without further distractions... ;)
          The car is a base M44'd 318i 4 door... so it may not have an amp in the stereo either. I'll have to look into that.
          Thanks,
          -C
          Below the radar...
          • FredK
            • 14759
            Yeah I dropped a CD43 into my E36. It was one of the few jobs I've done to my car that wasn't complicated by rust.
            • StereoInstaller1
              GAS
              • 22679
              I LOL'd
              Closing SOON!
              • UNHCLL
                • 8789
                You know there is rust on the steel assembly that holds the dash together right? I've seen it on every e36 that's been stripped for race prep!
                OH NOES... ALL UR RUZT BELONGS TO US
                Below the radar...
                • FredK
                  • 14759
                  Ya, stuff on the interior still gets frozen with light corrosion. I had to replace a lock cylinder and ignition switch bracket on the car, and the breakoff torx screws were stuck SOLID.
