FAQ: Difference between Components and Coaxials
This is a sticky topic.
  • kencopperwheat
    King of Kegstands
    • 14396
    Component Speakers:
    The Speaker system is made up of separate 'components', the woofer, the tweeter, and the crossover. Better sound reproduction is achieved by separating each component and controlling which frequencies are played by each speaker.
    Example:
    The larger diameter speaker is the woofer - it plays low frequencies.
    The small speaker is the tweeter - it plays very high frequencies.
    The 'box' is the crossover - it controls which frequencies are played by each speaker.
    Coaxial Speakers:
    The speaker is an 'all-in-one' type system. The tweeter is mounted in the center of the woofer, and there is usually a small capacitor to control the frequencies played by the tweeter.
    Example:
    Originally posted by Gruelius
  • LikeCDoos
    • Jan 2004
    • 2522
    Is there a HUGE price difference between the 2? How hard is the install with component speakers VS. coaxial?
    • kencopperwheat
      King of Kegstands
      • 14396
      From the same manufacturer, components are usually close to twice as much as a coaxial.
      The coaxial is pretty much 'plug and play', whereas with the component speakers you'll need to mount the tweeter separately from the woofer. You'll also have to find a place for the crossover and run cabling to and from it.
      • chesster6969
        • 321
        Get the premium stereo system tweeter pods and mount your component tweeters there. You can use the stock wiring to the tweets in order to keep it simple.
        • Jand3rson
          • 37587
          AWESOME thread, Ken. I have always wondered what the difference is.
          • Dominick
            • Aug 2004
            • 323
            nice post!
            now what are reference speakers?
            www.ThundaCats.com
            • bimmerphile
              • 3495
              Originally posted by Dominick
              nice post!
              Reference is a product line shared by several manufacturers (MB Quart and Infinity both have "Reference" speakers). That's all. It's not like there's a set standard for clean response and this many Hz with this many watts or anything like that. They just share a name.
              • natorious
                • 672
                there is also a third type (which are really nice in my opinion)
                integrally mounted components
                basically is a component system in a co-ax configuration but the tweeter is mounted over the woofer not through it... and they have real crossovers..
                an example of this would be the mb-quart qm-100 (which sound amazing)
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  The Boston Acoustics Pro and Z-Series speakers are also integrally mounted components.
                  • StereoInstaller1
                    GAS
                    • 22679
                    Basically, any coaxially mounted speaker with an outboard crossover are "integerally mounted components".
                    It is nothing more than a marketing term. They are still co-axes.
                    Jensen invented the coaxially mounted speaker way back in the 30's as a means to make the tweeter and woofer work better together. Back then, when most products were sold as a kit, (where you built you own cabinets) Jensen was the shizz.
                    Take a close look at most any manufacturers cheap series of components, and you will see it is the same as the co-axes, but with cheaper crossovers.
                    Take a look at the top of the line stuff, they are the same.
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • BMWguy
                      • Jan 2004
                      • 482
                      Jensen now owns MB Quart, do they not?
                      • StereoInstaller1
                        GAS
                        • 22679
                        No, Rockford Fosgate owns Quart. Paid way too much for them, and basically lost their ass.
                        Luke
                        Closing SOON!
                        • StereoInstaller1
                          GAS
                          • 22679
                          Edit:
                          UPDATE: MB QUART is now owned (and fuckin-ghey I mean OWNED) by MAXXONICS, the same fucktards that own "Dual".
                          Junk, I tells ya, JUNK!
                          HAHAHA, all of you retards that think Quart is the shnit!
                          Luke
                          Closing SOON!
                          • DSchultz325e
                            • Aug 2004
                            • 1158
                            I think the only line that was affected (actually it didn't even exist until the buyout) is the Discus line. It's made in China garbage. AFAIK Quart still runs the rest of their production out of Germany and their quality control has not changed. Nonetheless, I've never cared much for them, seeing as how I could never stand MB Quart's metal dome tweet anyway.
                            BTW, Maxxsonics is not Dual. It's Crunch, AutoTek, and HiFonics. HiFonics was once a good brand, but now they are turning into crap. I'd assume it's only a matter of time before Quart does the same...
                            I retired my E30 for now...
                            E46 323i
                            David Schultz
                            • StereoInstaller1
                              GAS
                              • 22679
                              Yup, David, good call. http://www.dualav.com/press/2004/2.html
                              Discus has been around since at least '91. Was always made in China.
                              Quarts' metal dome sounds much better if you put a band-aid over it. My bitch is power handling and lack of midbass.
                              While we are whining about this crap. go take a look at http://www.exilecaraudio.com and let me see you opinions. This is 3 guys from the old days of Phoenix Gold, designing and selling Chinese stuff, but with their own twist. I signed a dealer agreement yesterday (4/11/06)
                              Luke
                              Closing SOON!
