So I'm busy trying to figure out how best to get a subwoofer setup in my car. I've come up with a couple of ideas, some of which are from this forum.
4x 8-inch subs in the trunk
Problem with this is apparently bass still sounds as though its 'trapped' in the trunk, seeing as E30 trunks are pretty much sealed from the cabin.
Subs in the trunk, with openings in the rear deck
I've got 6x9" co-axials installed on my rear deck right now, and I was thinking, what if I remove the 6x9"s, put two big rubber grommets where they used to be, so that sound from the trunk can get through? Might look a bit uggo though.
Knock out the ski hole and 6x9"s
And put subs in the trunk.
Mount a sub directly to the ski hole
My feelings on this are that there would be issues with the sound seeing as the subs are firing straight into the cabin towards the windshield? I don't know...
Put a 8" sub mounted on the rear deck ala IB
How does this sound?
2 8" subs mounted in the rear door panels
And 2 in the trunk?
Or any combination of these.
I want loud bass, but nothing that sounds like crap. SQL, if you will. What do you guys think?
And 2 in the trunk?
