Ok I never post here
  • M-technik-3
    • 18946
    but I brought all my stero equipment from My m-tech car back to the states. And my amp that was in the car is a Pioneer GM-1200 70w+70w unit bridgeable. Is this a halfway decent amp and where should I draw power por it in the trunk? I want to make it switch on when the stero comes on.
  • UNHCLL
    • 8790
    Re: Ok I never post here
    You'll have to run a remote turn on wire from the back of your head-unit.
    Since we're lucky and the batterys are in the trunk, just get an amp power kit with inline fuse and connect it dirrectly to the battery.
    btw,
    you going to come up this week for the tires?
    Below the radar...
    • M-technik-3
      • 18946
      Yup gonna try to my schedule is busy but, I need some rubber under the feet for the car.
      • Rob
        • 8166
        Most of the time, amps are turned on using a seperate wire from the head unit. If you have a stock head unit, or for whatever reason dont want to run a wire, I dont see why you couldnt use one of the wires for the power antenna, since that is only powered when the radio is on...
        BEERTECH
        • M-technik-3
          • 18946
          I think Chris's idea about a remote switch is correct, then with a large gauge wire for power feed from battery to amp itself. I have an Alpine CDA 5453 headunit/amp/cd. It's nice as it has rca outputs and inputs which the amp does also. It shouldn't take more than a half hour to and hour to wire it.
          • Rob
            • 8166
            ok, yeah since you have an aftermarket deck, that would be the best way 8)
            BEERTECH
