bench test power antenna
  • 330SMG
    • Feb 2007
    • 172
    I have an OEM antenna that I want to check before I put in the car. Am I correct in thinking that I put a contannt 12v to the red wire and black to ground and jump 12v to the white wire to activate the motor. TIA
    I did a and no answer there.
    1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    i believe so. it also wont work unless its grounded itself and to the ground jumper wire. you know it isnt that hard just installing it. and while your messing with it, replace the rubber grommet with a new one. its worth the $2 and prevents trunk rust
    • PiercedE30
      • Apr 2005
      • 4220
      White wire doesn't need to be hooked up to +12v.q
      My 2.9L Build!
      • DaveSmed
        • Apr 2007
        • 1407
        ....If you just want it to retract. Hook up the white wire to get it to extend.
        -Dave
        2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
        Need some help figuring out the ETM?
