Mounting Depth
    Mounting Depth
    whats the maximum mounting depth in the kick panels without modification?
    Pull one out and get a ruler. I'd say it's 2.5-3"
    Originally posted by Gruelius
      try checking www.crutchfield.com to see what fits. i think they have a 2" top mounted as the biggest
      FOKAI DA'MA'SHI'I ENSANE GRAPPING INT.
        I used to have some Image Dynamics CX5s in the front stock locations and they fit just fine with a 2.3" mounting depth. There was room to spare behind them... half in or so I'd guess.
          If you're using coaxils it's not the depth you need to worry about, it's if the kick panel will fit over the tweeter. As Ken said take a speaker out (passenger is easier) and measure it. I'm sure most 5.25 components will fit, however I can say the same for coaxils.
          M
            my 5.25 excelons wont fit with the kick panel on the drivers side, the tweeter is to tall
            BEERTECH
              Yeah, you'll run into problems trying to fit certain coaxials down there.
              But as far as raw 5.25" drivers, you shouldn't have a problem fitting any down there.
                nah im running components, imma run diamond audio hex's and they only have a mount depth of 2-1/8" for the 6.5's so im going to try and run those. if not ill just run the 5.25's. thanks for the help.
                  You will be fine with the 2 1/8. I have 6.5s with a 2 1/2 depth.
                    i just got my focals, they are about 2.3 or so inch mounting depth. My question is do you recommend using the stock kick panels to cover them, or am i better of modifying it to fit the grills. I am pretty sure these grills will render the glovebox and hood latch useless. anyone?....
                      Are you able to fit the 6.5"s in the stock location? If so, just remove all of the crap off of the back of the plastic kickpanel covers and use those.
                      It'd probably be ok to mount the 6.5" midbass speakers in the stock locations because bass is omnidirectional. But you'll probably want to make a little pod enclosure in your door for the 4" midrange (as it will be playing most of the frequencies).
                      PM or IM me and I can help you figure it out.
                        did jordo ever finish his speaker pods btw?
                        BEERTECH
                          yeah the 6.5 will fit, or it seems as though they will. I just have to make new mounting points for them. I am going to make a small door pod out of the map pockets and fiberglass to house the 4 inch speaker, and probably put the crossover in there as well.
                          ken i'll hit u up on IM when i get a chance, i need to order the RCA wires yet anyway so i have some time to plan.
