13button obc question
  • scobaru
    • Nov 2007
    • 396
    sorry for snagging this picture from a member, but what the heck is that black box the obc is connected too? I bought a 13button set up and doesn't have that black box....
  • AndrewBird
    The Mad Scientist
    • 11898
    I'm pretty sure it's the computer for it. It controls everything the OBC displays. It also makes the stalk on the steering column work.
    Someone correct me if I am wrong.
    • scobaru
      • Nov 2007
      • 396
      I guess I'll correct you... my obc stalk works, time and date works too. mpg, temp stuff doesn't work but I have the wrong coding plug and unsure if my temp sensor is even good.
      • houstonh
        • Aug 2007
        • 293
        I dont have that box and Temp,Mileage, Fuel monitor, etc all work just fine on my car. That may be for coding on the ignition
        • PiercedE30
          • Apr 2005
          • 4220
          That is for the coding function. Make sure if you are retrofitting the system that the relay inside the black box is good and that the solder is good. I had to replace that box the day of an AutoX and didn't make it to it because of it.
          My 2.9L Build!
          • AndrewBird
            The Mad Scientist
            • 11898
            Wow, I was way off. So all it is for is the ignition disable function?
            • PiercedE30
              • Apr 2005
              • 4220
              Yup. It has a wire that goes from the key to the box, the power side of the relay, and the other wire goes to the big green wire in the C101 and powers the ecu. The OBC just controls whether or not the relay is going to feed power or cut it.
              My 2.9L Build!
