I can has a/d/s/ and C43 radio swap?
  • bimma360
    • 1940
    Originally posted by NitroRustlerDriver
    Is this the stuff that James had? If it is, I'm surprised he sold it. I thought it was going in his car.
    Looks great.
    You talking about the James with the dinan turbo e30? If so, then yes it was his stuff... haha. I bought his dinan e30 for its drivetrain back in April.... and since i already have an mb quart system i thought i'd pass the ads stuff to someone who can get some use out of it.
    Dave
    E30 Dinan Turbo
    • StereoInstaller1
      GAS
      • 22679
      Originally posted by Aptyp
      my stupid questions shall continue, these c33/43 models came out of e36? or something else?
      Several of the mid-90s BMWs came with the CD43 or other "Business Class" decks
      What speakers and why? You had to get wiring from somewhere else? How come?
      He is using component speakers both front and rear, with a subwoofer. The wiring he needed was basically the plug from a BMW harness, which is available aftermarket. Simple power and ground, smae as the plugs on the back of your Alpine
      What's that in the trunk if not an AMP? If it is an AMP, why didn't run AUX cables already?
      Yes, that is a 4 channel amp, a 2 channel amp and an electronic crossover, all classy as hell old school ADS.
      by AUX cable you mean RCA's right?
      NO, AUX refers to an input on the deck, typically from an iPod to the "AUX" input.
      Can you do a write up, because I will be bugging you with noobie questions. Installing Alpine was a breeze afte I rewired the whole car, but this is by far more interesting to me.
      So when you rewired your car, if you ran all the speaker wires to the trunk and connected them to an amplifier, along with RCAs and a remote wire (power is already in the trunk) you have completed an amp install.
      Closing SOON!
      Thanks for 10 years of fun!
      • AndrewBird
        The Mad Scientist
        • 11898
        Dave
        I was talking about Criv actually.
        • bimma360
          • 1940
          Welp... alrighty then.
          E30 Dinan Turbo
          • Gooch
            • Dec 2006
            • 1674
            my stupid questions shall continue, these c33/43 models came out of e36? or something else? What speakers and why? You had to get wiring from somewhere else? How come? What's that in the trunk if not an AMP? If it is an AMP, why didn't run AUX cables already? by AUX cable you mean RCA's right?
            I think Luke nailed all the questions, if you have any more, feel free to post them up.
            My C43 is out of a 1999 318tiA. I used this harness.
            All I did was run the speaker wires to the crossover (left in trunk pic) then an 8 pin DIN cable connects the crossover to the amplifier, and another set of speaker wires run from the amp to the speakers. Power and ground for the headunit are taken from the factory location up front, two remote turn on wires were run down to the amp and crossover, and power and ground for the amp and crossover were provided by the battery. I installed a 20 amp inline fuse to the amplifier as to the PH12's owner's manual.
            The speakers were just personal preference, I knew I wanted a/d/s/ because I had heard they were fantastic (and period correct), and these pretty much fell into my lap. The 6 channel amp and 642CSi crossover are capable of handling everything; the fronts (which I'll find eventually), the rears, and the two subwoofers.
            Originally posted by SuperDuper
            Find yourself a nice set of 320is's for the front and you'll be set. Nice install!
            I'm on the hunt.
            '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
            '87 535i - Vacuum brake conversion [SOLD]
            '93 525iT - 5-speed swap - 320k and counting
            '09 328xi - 6-speed
            • 87Blue325iC
              • Apr 2006
              • 1111
              My post from awhile back might help too...
              Aaron
