C33 AUX input and Installation Megathread
  • Todd Black 88
    • Oct 2007
    • 3449
    #46
    Originally posted by digital_cowboy
    After researching more, it sounds like the C33 will output directly to the amp. It was suggested to run the channels to RCAs and use a body ground.
    Output voltage is ~9v. This makes sense as the c33 (and most other oem head units) are designed to feed a oem amp.
    Not sure it this is helpful, but perhaps a signal converter (such as this one) could help.
    i bought that exact one at walmart. says its capable of converting to a common ground system like ours. I hope to install this weekend.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • Todd Black 88
      • Oct 2007
      • 3449
      #47
      I tried it, and got no sound. I called the tech support and they were no help, and said it was not tested on bmw's system so it probably won't work.
      2010 F650gs twin
      • kronus
        • Apr 2008
        • 13029
        #48
        I had the system wired up and amping properly outside the car, C33 tied to 4-channel amp directly, with no signal converter. Is one needed for direct amp output?
        I'm just confused as to whether you can fork RCA cables.
        cars beep boop
        • Todd Black 88
          • Oct 2007
          • 3449
          #49
          No you don't need it, but it is recommended to convert to rca's due to noise interference on speaker wires.
          2010 F650gs twin
          • digital_cowboy
            • May 2008
            • 335
            #50
            What does "fork" mean?
            What ground did you use in the RCAs? I am going to use a chassis ground upon Luke's advice.
            -Will
            1987 325is, 1989 325i, 1997 318i
            Parts for Sale
            • StereoInstaller1
              GAS
              • 22679
              #51
              Do NOT use the pile of shit scosche line output converter. The damn deck is already a low level deck!
              The C33/CD33/CD43 decks are NOT speaker level (unless out of an E36 318) but will run speakers in a pinch.
              Closing SOON!
              Thanks for 10 years of fun!
              • digital_cowboy
                • May 2008
                • 335
                #52
                Here is my plan for c33 to 4 channel amp setup. Does it look correct?
                -Will
                Parts for Sale
                • kronus
                  • Apr 2008
                  • 13029
                  #53
                  I'm not sure about leaving the signal grounds on the C33 connector unattached. However, I'm also not sure about grounding them to chassis.
                  Otherwise, looks like what I'm doing. Does your 4-channel amp have a passthrough for another amp?
                  cars beep boop
                  • digital_cowboy
                    • May 2008
                    • 335
                    #54
                    yes, but the second amp and sub will be a later project. Also, as my car is wired for premium, I *think* I can use the stock wiring from the HU to the AMP and from the AMP to the speakers.
                    -Will
                    Parts for Sale
                    • StereoInstaller1
                      GAS
                      • 22679
                      #55
                      I have done about 30 cars like that, using several different combinations of amps. Have yet to have an issue.
                      Except for the goddamn E36 4 banger cars...no factory amp!
                      Yes you can, but you may want to use the yellow/black, yellow/red, blue/black, blue/red as signal positives if your car has a fader.
                      Closing SOON!
                      • Todd Black 88
                        • Oct 2007
                        • 3449
                        #56
                        Is there any way to use the stock premium system, amp etc with a c33 or other factory e36 deck? If so, how do you wire it into the e30 properly?
                        2010 F650gs twin
                        • StereoInstaller1
                          GAS
                          • 22679
                          #57
                          Yeah, easy stuff.
                          Yellow and blue with red and black stripes are the positives, then chassis ground the brown/orange wires and do NOT use the spaker negatives off the deck.
                          Sounding familiar yet?
                          Closing SOON!
                          • Todd Black 88
                            • Oct 2007
                            • 3449
                            #58
                            No,.................. i'm dumb though.
                            2010 F650gs twin
                            • Todd Black 88
                              • Oct 2007
                              • 3449
                              #59
                              The diagrams i have show the brn/org wires off the e36 deck are the speaker negatives though. So I just ground those wires to the car chassis and hook up the positives to the e30 positives?
                              Sorry for the thread jack.
                              2010 F650gs twin
                              • StereoInstaller1
                                GAS
                                • 22679
                                #60
                                That is precisely it...but make damn sure to hook BOTH E30 white wires (antenna and amp remote) to the white wire on the CD43
                                Closing SOON!
