speedo, odo, and obc light no workie
  • aaron325ix
    • Jun 2007
    • 1489
    I did some searches and could not find anything like this. At first my speedo/odo stopped working suddenly the other day. Was driving home, worked fine 30 min later didnt work. Then i noticed my obc doesnt light up as if the light bar went out. I find it hard to believe these 2 are not connected.
    I checked the connection at the rear diff: fine
    checked all fuses: fine
    all connections behind cluster: fine
    pulled out speedo: gears and all seemed fine
    anyone else ever seen this. I'm stumped
  • e34john
    • Apr 2006
    • 3599
    Theres a speedo sensor in the differential that might be causing your problems but I dont know how that could effect your OBC.
    • kenika65
      • Aug 2007
      • 1336
      Check it out, it is the + prong that connects to your speedo in side your cluster. You will see 4 or 5 prongs that plug in to your speedo, one of them is the +, this one will have a broken solder that should be re-soldered.
      It says which prong is + on the speedo it self.
      Ill take a pic if you need.
      1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
      1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
      • aaron325ix
        • Jun 2007
        • 1489
        I think I know what you are talking about but I did not notice any thing out of place. Would you mind taking a pic? Thanks.
