i had one lying around for ages, i installed today (too easy) but i couldent find a red wire it had an extra blue and a white wire, so i used the antenna power since i shaved mine off. anyway works great, I just wish i read this sooner. Thank you!!:up:
My Favorite $30 Mod so far...(keyless entry)
This is a sticky topic.
is there an alram install floating around somewhere or is the keyless entry an alarm itself, and what about remote start? anyone?
I love that e30s can start without the clutch down(makes it feel like more of an import)97 tacoma 5 spd 4 cylinder
2001 330ci 5 speed
83 733i 5 speed, (FS)Comment
There are some real cheap remote start systems without keyless, and there are add-on modules that add remote start to a keyless entry or an alarm.
Basically, have it your way.
LukeComment
if my central locking doesnt operate correctly, this kit will do me no good, correct?
im able to lock the passenger door, but the driver door lock doesn't stay down. and the cylinder for the key is fubared as well.Claus Luthe is my hero.
No but I'm all ears.
I just bagged me one last night on eBay for $20.50 including shipping!!!
Can't wait to install it,(no more walking behind the car to the trunk to unlock) I bought this as I cant deal with installing a real alarm.
I feel like a trator sorry Luke.... If you where closer or I had a competent friendly installer in my area.sigpic
WTB-Strut BarComment
Dammit, mine stopped working after one year. It seem to happen as it got colder here.
If i remove the power and plug it back it, it will work, lock unlock......
I walk away from the car for 30mins, and it stops working.
I opened it up and nothing appears to be burnt out.Comment
ok, what the hell. all of a sudden my keyless stopped working. this after working perfectly for 3 months. central locking still works like it should
so i pulled the unit out, unplugged it, and plugged it back in. locks work again. however after letting the car sit for a an hour or so, it stopped working again. it's not a wiring problem. it's almost like the unit is malfunctioning. anyone else seen something like this?
Did you ever find the problem?Comment
Hope this helps.
I have a 90 325is and ours should be the same wiring. There are 2 bundles of wires in the trunk by the amp. Make sure your grabbing the bundle that has all the tape around it. its the smaller bundle. GL.
