My Favorite $30 Mod so far...(keyless entry)
This is a sticky topic.
  • priapism
    • 1182
    #391
    Originally posted by cbouchez
    Fix your central mechanism first.
    It works fine.
    -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
    • cbouchez
      • May 2007
      • 2789
      #392
      When you use your key on the driver side locks all all doors and trunk?
      Follow my IG @bouchezphotography
      • cbouchez
        • May 2007
        • 2789
        #393
        Where is a constant 12v power source
        NO battery in trunk
        NO antenna in the trunk.
        Any other options?
        Central locking mechanism has 4 wires.
        1 unlock
        2 lock
        3 ?
        4 ?
        • cbouchez
          • May 2007
          • 2789
          #394
          I have the ddor lock actuator with a:
          white=
          blue =
          brown = ground
          green/black (I think) I know it controls the lock
          greenk/blue (I think) I know it controls the unlock
          Which one is constant 12+
          • BrooklynMW
            • 1263
            #395
            Holy hot shit I finally got this thing working. Had to replace my CL computer and a couple of actuators. Still, I can't figure out if it's possible to use the double button feature that pops open the trunk. Anyone have any success with this?
            I realize that the blue wire on the 4 pin is reserved for trunk latch, but I'm not sure where to stick it.
            '87 325i "Chewey" (RIP, my beloved)
            current:
            '01 e46 325iT "Dot" - #datwagonlife
            '87 e30 325i "Tui" - she has her mother's eyes
            • JCarp90
              • Feb 2011
              • 1759
              #396
              Does anyone know of a more up-to-date install thread for an E36? I've got the Omega K-9 Mundial 4 alarm.
              • george graves
                • 19996
                #397
                Read the sticky.
                Originally posted by Matt-B
                • 330SMG
                  • Feb 2007
                  • 172
                  #398
                  white=
                  blue =
                  brown = ground
                  Please for a wiring diagram...it is your friend when doing anything on a BMW.
                  1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
                  • Aahj
                    • Nov 2011
                    • 84
                    #399
                    Anyone tried this kit?
                    AJ
                    • iwantspeed
                      • 3164
                      #400
                      like to report back:
                      I have been using the omega rec 43 for over a year now and no problems
                      keys went through the washing machine and dryer and the unit is still working.
                      Project
                      Parts for Sale
                      Feedback
                      YouTube Channel
                      • cbouchez
                        • May 2007
                        • 2789
                        #401
                        I got mine to work a while back and works just fine unlocks all 4 doors and trunk. Flashing lights would be great but for the $ its alll good.
                        • iwantspeed
                          • 3164
                          #402
                          can we add a aftermarket horn.?
                          and tap the lock wire to trigger a relay for a horn?
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • bastianshaw
                            • Jan 2007
                            • 2210
                            #403
                            can some posta fresh link to the e46 keys w a whole kit?
                            • trackjunkie21
                              • Jan 2010
                              • 3962
                              #404
                              Originally posted by acolella76
                              depends why your antenna doesn't work...
                              Maybe this would be a good place to post my question.. I installed my system a couple months ago, and only got the lock function to work. I cut into the trunk wires to use the trunk lock. I wired everything up correctly, except it won't unlock. Even if i stick the key in the trunk and unlock it it will not unlock all the doors. Anyone know whats up?
                              I had a similar problem, turned out to be a wire that got cut under my seat.
                              Originally posted by Wh33lhop
                              VANOS: sometimes you just need to go full retard.
                              • 'e30love'
                                • 893
                                #405
                                installed today works awesome.
                                wire color is correct just needs to have the two wire pin installed as well. same colors apply. for constant i read the res wire to the antena was being used. sure enough it works with it. i attached red wire to re wire on the antena. just need to go back and clean up some wiring.
