My Favorite $30 Mod so far...(keyless entry)
This is a sticky topic.
  • dubdub
    • Oct 2007
    • 293
    #496
    I feel dumb that I didn't think of changing the battery in the fobs.
    Originally posted by 15Michaeljoseph
    Try a different fob (should come with 2)...change batteries in fobs... Relocate the antenna on the unit in the trunk.
    I think the antenna is the biggest part. What I did was I used extra wire and spliced it onto the end of the antenna, and ran it all around the trunk. Works really good... About 10-15 ft. RELIABLE range. Much beyond that, it gets a little more sketchy.
    Sent from my XT1064 using Tapatalk
    • dubdub
      • Oct 2007
      • 293
      #497
      Okay, so I replaced the batteries. Solid improvement... but it only unlocks. It doesn't lock. Any guesses?
      • george graves
        • 19986
        #498
        Open up the remote and use isopropyl alcohol to clean the PCB would be my first move. Not to say it will fix it. But between the rubbery key pad, and the PCB it might have some oxidation/oil/junk. On the underside of the keys, there will be black nub. Don't fuss with it too much, just clean it lightly.
        How old is your unit?
        Originally posted by Matt-B
        • dubdub
          • Oct 2007
          • 293
          #499
          Brand new. Just installed and trying to get working. An intermittent problem, where it would not work with regularity, called for new batteries as a solution.
          I swear, despite intermittently working, they did lock previously.
          • tito12121
            • Nov 2016
            • 33
            #500
            Im assuming its somewhere in there 30 pages but can someone repost or just tell me where to get the 12v constant in the trunk, I have a 325ic and the battery is up front. Im ordering the REC43 and following instructions from the first post.
            • 15Michaeljoseph
              • Aug 2013
              • 1693
              #501
              Power antenna wire.
              (OO=[][]=OO) For Life
              • cspec
                • Apr 2017
                • 182
                #502
                Best bang for the buck mod!
                • Eric Giles
                  • 1067
                  #503
                  I have my first Omega keyless entry in my '87 325is, and 9 years later it still works perfectly. But since I wasn't able to find the same thing for my latest E30 acquisition, a quick search found a cheaper unit that works just as well.
                  It seems that the Docooler keyless entry system that is only $15.49 on Amazon is very popular, with overall good reviews. The real issue being that the included wiring diagram is difficult to read, and on top of that it is incorrect.
                  Once I got the central locking system to work (it was the infamous red/black stripe power wire that runs needlessly thru the door wiring harness), I installed the Docooler keyless entry. As I did in my 325is, I pulled back the trunk liner on the left side of the trunk and tapped into the trunk lock wiring bundle.
                  As mentioned, the included wiring diagram with the Docooler is incorrect...in that what is labeled as the positive trigger setup is actually the negative trigger setup, and vice versa. Since the E30 is negative trigger, then do this:
                  Connect the White (Lock) wire from the Docooler to the E30 Green/Black Stripe wire.
                  Connect the White/Black stripe (Unlock) wire from the Docooler to the E30 Green/Violet Stripe wire.
                  Next, take the Yellow and Yellow/Black stripe wires that come from the Docooler, along with the Black ground wire, tie them together, and connect them both to Ground. I used the ground point for the power antenna, which is a 10mm bolt on the power antenna bracket. Remember, on the wiring diagram this connection type shows it is for positive trigger...but it is incorrect. This configuration will work for your E30 (or any BMW that uses negative trigger for the locks).
                  As far as power, just tap the red wire on the Docooler to the red power wire on the power antenna harness. That's it...as with the other systems mentioned in this thread, I just used some velcro tape and mounted the unit to the inside of the quarter panel, behind the trunk carpet. Remote range is very good...distance does not seem to be an issue with this unit. The remote fobs are of higher quality than the Omega units, with the attachment point for the keyring being larger and sturdier.
                  Eric Giles
                  '20 M2 CS
                  '04 M3
                  '11 X5 35D
                  '87 325is
                  '91 325i Sport
                  There are few things more expensive than a cheap BMW...
                  • zwill23
                    • Jul 2015
                    • 615
                    #504
                    I went ahead and purchased the Docooler keyless entry that Eric recommended and I'm happy to report that it works fantastic. I'm very impressed, and for $15 it's a no brainer.
                    The only thing to add to Eric's write up is that the black ground for the Docooler itself also needs to be grounded. This is obvious for those who are savvy with electrical, but just wanted to include that bit of info for completeness.
                    I also removed all of the additional unused wires from my unit for a clean install, and used heavy duty outdoor velcro rated for use at temps up to 150deg. We'll see if it holds up to the Texas heat :up:
                    • aaron325ix
                      • Jun 2007
                      • 1489
                      #505
                      So I just wired this up just like you guys did. I tested it and it worked fine. Once I buttoned everything back up it stopped working.
                      When I hit lock/unlock the the box makes clicking sounds like a relay.
                      All the wires are connected just fine, no blown fuses. Any ideas?
                      • zwill23
                        • Jul 2015
                        • 615
                        #506
                        Actually, I think I know exactly what you did because I did the same thing.
                        The central locking system wiring is very small, 18-22AWG I believe. When I first wired this up I used 16-14AWG splice terminals and the system worked perfect upon initial installation but then became very intermittent shortly after driving the car around.
                        Make sure the splice terminals you are using are for 18-22AWG, similar to the red terminals in this pack:
                        I'll bet that fixes your issue!
                        • aaron325ix
                          • Jun 2007
                          • 1489
                          #507
                          Thanks, I'll check that out. did you cut the unused wires or disconnect them from the plug terminal altogether?
                          • zwill23
                            • Jul 2015
                            • 615
                            #508
                            No problem. I disconnected the wire terminals from the plug all together. I used a pick to depress each terminal on the Docoder plug. They pop right out.
                            I'm sure a small screw driver would work too if you don't have a pick.
                            • m5james
                              • Feb 2012
                              • 59
                              #509
                              Bumping this thread to keep the info in one place and in hopes someone can recommend a cheap alarm like this that also has remote start. Searches have only lead me to $100+ systems or dead end threads with dead links. This Docooler is lkke $18 now but searching for that brand on Amazon with remote stsrt only showed a push button which isn't what I'm looking for.
                              • mchang
                                • Jan 2015
                                • 40
                                #510
                                :thumbsup: to this OG post. Just installed https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and it went smoothly.
