Well then, I guess I'll give it a shot - I've never done a write-up before, hope it turns out good :)
My Favorite $30 Mod so far...(keyless entry)
This is a sticky topic.
I didnt know it was available or I would have. Also, no write up this weekend as my package will not arrive until Monday. Looks like it'll have to wait till next weekend. :(
They recommended it, but I did not double lock the car before getting the keyless entry and I don't think the key has ever touched the door lock since I installed the keyless entry (got first one over a year ago).Comment
regular locking is when you turn the key a little, then turn it back, so the slot stays vertical while locked. double locking is if you turn the key a full 90 degrees and leave it like that. the purpose of double locking is if you want to leave your windows open, and you double lock, no one can reach in and undo the lock from the inside with the pin.Dan
Cool man... I didnt know that. I guess I've never double locked my car then - and dont plan to either.
i used the red wire that connects to the antena. THere is a plug that connects to the antena, it has two wires, one is black one is red, the red is a constant 12vOriginally posted by DanGillanwhat did everyone use for the 12v constant power, mine comes in today, and I cant wait to wire it up.Luke
98 M3 with many goodies
i'm not sure how he did it, but i'll tell you how i did. What i did was unscrew the antena cable form the antena, then i stripped about 1.5 inches of from the antena wire from the keyless entry. Then, you how the antena cable is connected to the actuall antena, with that little fastener thing, well i snuck the keyless entry stripped wire through the little crack and i connected the antena cable back on.....sorry if it didnt make too much sense, and i am not sure if it improved the reception by much becase i didnt do a comparison.Originally posted by DanGillanthank you!
ALSO, weston said he connected the antenna of the system to the radio antenna, how do you do that?
LukeLuke
