My Favorite $30 Mod so far...(keyless entry)
This is a sticky topic.
  • TimmyBigHands
    • 260
    #46
    Well then, I guess I'll give it a shot - I've never done a write-up before, hope it turns out good :)
    • DanGillan
      • Mar 2004
      • 4061
      #47
      I just ordered one, it would be really cool to be able to wire it to the dome lights, parking lights, maybe even a bleep from the horn. has anyone done anything more with this stuff?
      Dan
      • DanGillan
        • Mar 2004
        • 4061
        #48
        also, did anyone choose to buy those 2 extra relays to make sure you dont bend your lock cylinders if you double lock with your key, then unlock with the remote?
        Dan
        • TimmyBigHands
          • 260
          #49
          I didnt know it was available or I would have. Also, no write up this weekend as my package will not arrive until Monday. Looks like it'll have to wait till next weekend. :(
          • Chris325/325i
            • 40
            #50
            They recommended it, but I did not double lock the car before getting the keyless entry and I don't think the key has ever touched the door lock since I installed the keyless entry (got first one over a year ago).
            • LikeCDoos
              • Jan 2004
              • 2522
              #51
              yeah since i've installed my keyless my key has not touched my door. Also what is the point of double locking, i know how to do it but what is the point?
              • TimmyBigHands
                • 260
                #52
                I guess I dont even really know what double locking is...?
                • DanGillan
                  • Mar 2004
                  • 4061
                  #53
                  regular locking is when you turn the key a little, then turn it back, so the slot stays vertical while locked. double locking is if you turn the key a full 90 degrees and leave it like that. the purpose of double locking is if you want to leave your windows open, and you double lock, no one can reach in and undo the lock from the inside with the pin.
                  Dan
                  • TimmyBigHands
                    • 260
                    #54
                    Cool man... I didnt know that. I guess I've never double locked my car then - and dont plan to either.
                    • Tinman
                      • May 2004
                      • 58
                      #55
                      I just completed. Very simple to do. Four wires and you’re done. I wired directly into the 12v at the radio antenna for power. I was always paranoid about breaking a key off in the cylinder, hopefully that won't happen now.
                      • DanGillan
                        • Mar 2004
                        • 4061
                        #56
                        what did everyone use for the 12v constant power, mine comes in today, and I cant wait to wire it up.
                        Dan
                        • 325is_MadBimmer
                          • Mar 2004
                          • 654
                          #57
                          i used the red wire that connects to the antena. THere is a plug that connects to the antena, it has two wires, one is black one is red, the red is a constant 12v
                          Luke
                          98 M3 with many goodies
                          • DanGillan
                            • Mar 2004
                            • 4061
                            #58
                            thank you!
                            ALSO, weston said he connected the antenna of the system to the radio antenna, how do you do that?
                            Dan
                            • 325is_MadBimmer
                              • Mar 2004
                              • 654
                              #59
                              thank you!
                              i'm not sure how he did it, but i'll tell you how i did. What i did was unscrew the antena cable form the antena, then i stripped about 1.5 inches of from the antena wire from the keyless entry. Then, you how the antena cable is connected to the actuall antena, with that little fastener thing, well i snuck the keyless entry stripped wire through the little crack and i connected the antena cable back on.....sorry if it didnt make too much sense, and i am not sure if it improved the reception by much becase i didnt do a comparison.
                              Luke
                              Luke
                              • spencers
                                • Jan 2004
                                • 1150
                                #60
                                Do you absolutely have to plug it into the antenna?
                                I mean, what good does the antenna do if it's a power antenna and its down when you exit the car? I'm guessing it still supplies a little bit of reception?
