/noob post haha (forgive me as im new to e30s :) )
ok now everyone is doing this to their e30s it seems, and they have power locks, generally i think of power locks as lock button on the door but the e30 has no lock buttons on the door but if i turn the key 90 degrees all the doors lock or unlock, just like if i unlock/lock through the trunk, so im assuming this is the same setup as everyone? and i will be able to use this keyless entry,
im assuming this is the one everyone is talking about correct?
and just wire it in the trunk as everyone else was talking about?
thanks
and if this is what you guys are talking about then i think ill be ordering one in the morning :) woohoo
itll definetly come in handy in the rain when trying to run around the car opening the other door for people :)
thanks
Why is there so much excitement over a simple keyless entry unit? This has been done for eons as an add-on to aftermarket alarms. It's so easy on an E30 with central locking. I just installed an AutoPage 310 alarm (a very basic unit) in my 86 e, tripping the locks with one alarm output and a relay. I also added a power window module to have the windows roll up on arming, and used the trunk release output (since it's not needed anyway with central locks) and a couple more relays to do pulsed windows down the old school way. It did mean tapping into the wiring behind the window switches, but all this added bling only cost a buck ten, including the alarm. 8)
