Aftermarket head unit install question
  • dwforum
    • 220
    I just got my new Blaupunkt Montreal cd34 head unit in the mail today, and will probably try and install it myself the next day i get off from work. I was wondering though if anyone knows where I could pick up a wiring adapter and an antenna adapter. This will be my first time installing a head unit, so I am not sure if these are vehicle specific parts, or where the best place to find them is. Thanks
  • e30evolution
    West Werks
    • 1888
    magnolia hi-fi, or similar place.... most likly no one will stock the part though.....
    look on the internet, or start chopping up the wiring harness.
    you may need to run all new speaker wire, because the factory speakers are grounded to the chasis...... you will get al kinds of interferance from the engine if you dont ground the speakers to the headunit
    http://www.westwerksauto.com
    • dwforum
      • 220
      one of the previous owners installed new infiniti speakers and had an aftermarket cd player in the dash at one point, does this mean I may not have to completely rewire?
      • BahnE30
        • 1050
        should be good to go
        set your deck up to run fron't left and then find out which wires come of the deck go to front left and find which wires go to front left speakers make the connection continue on adjusting the fade until you get them all done
        antenna shoudld plug into back of deck no problem and chances are if PO had another deck in it wiring harness is chopped and new wires are run
        no biggie thou
        • dwforum
          • 220
          thanks for the responses, hopefully I'll have my new deck in by the end of the weekend
