removing the stock door tweeters
  • der affe
    Technical
    • Dec 2005
    • 8452
    i want to pull out the stock tweeters in the door and replace the tweeter itself with a similar sized, but higher quality tweeter.
    i was trying to get one out today and it seems pretty stuck.
    are they glued in?
    can i carefully use a heat gun to soften the glue if there is any?
    thanks
  • kenika65
    • Aug 2007
    • 1336
    router...
    1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
    1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
    • der affe
      Technical
      • Dec 2005
      • 8452
      a large hammer?????
      to clarify i want to keep the stock grilles in place and mount the upgrades behind them
      • kenika65
        • Aug 2007
        • 1336
        yes use a router to get them out then you can either glue or mount in the new ones....
        • dashboardmonkey
          FUCK YOUR WAFFLES
          • Jun 2008
          • 6158
          A router? No.
          Just pry it out with a screwdriver from the inside.
          -Andy
          • der affe
            Technical
            • Dec 2005
            • 8452
            you mean like a dremel?
            a router is a pretty big piece of machinery
            • der affe
              Technical
              • Dec 2005
              • 8452
              Originally posted by dashboardmonkey
              A router? No.
              so they are not glued. they are just being stubborn.
              • dr.strangelove
                • Jan 2005
                • 847
                this is what i do. Remove the rubber window seal strip that (surrounds the window) just behind the tweeter. then you will see a silver clip behind a small hole. push that tab towards the front of the car, and towards the interior. That is the metal clip that holds it in place. Be careful removing it in order not to break the plastics posts that keep it lined up.
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  thanks, but i think you misunderstood my post. i am trying to take the tweeter out of the pod that is located on the door. not remove the pod from the door. that is already done
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    They are glued in, but a little careful prying will get them out. Try trimming all the way around them with an exacto blade first. After you get them out, use hot glue to mount the new ones.
