dual voice coil question
  • e30ct
    • 87
    I was wondering if you can damage a dual voice coil sub if you run just one coil? Someone told that ou are NEVER supposed to do that but he could'nt tell me why.
    Any comments welcome.
  • Jordan
    • 12907
    You must operate a DVC sub with both coils being driven.
    Damage can/will result if you drive only 1 voice coil. JL voids all warranties if you connect only 1 voice coil.
    Both voice coils should also ideally be fed the same mono signal.
    https://mtechniqueabs.com/
    • colt325e
      • 228
      What would be the point of only running one???
      • SpeedDemon_e30
        • Sep 2004
        • 48
        yeah what would be the point?? If you want a single then sale the ones you got and get a single.. Other wise run both to be on the safe side..
        • e30ct
          • 87
          I always intended to run both coils which is what i'm doing right now..i just had one coil hooked up when i first put it in because i was in a rush to see what it sounded like..I have the coils hooked up in parallel now.
          • 808BMW
            • 2910
            Didn't want to wait the extra 10 seconds?
            • kencopperwheat
              King of Kegstands
              • 14396
              Exactly what I was thinking....
              Originally posted by Gruelius
