fuel gauge PLEASE HELP!!!
  • e30power7931
    • Jan 2009
    • 20
    Sorry if this is in the wrong section..im new.....my 87 325is has a strange gas gauge. bare with me im gonna explain lol. When i reach half a tank im empty and the light comes on.....i have replaced the fuel sender numerous times and checked the ground and tried other working gauges but nothing helps....when i hit empty i can only add 12 gallons tops.....im so confused. PLEASE HELP ME!! lol...Has anyone ever even seen this happen before? even my master technition who has worked on e30s and e28s forever is stumped....once again Thanks!
  • accident
    • 7303
    How big do you think your gas tank is? IIRC the e30 tank is between 14.5-16.5, and if you're hitting gas light and putting in 12 gallons it sounds like you're pretty on par.
    Moral of this story?
    • e30power7931
      • Jan 2009
      • 20
      i think its a 15 but i have no idea im still pretty new to bmws lol....but im mostly concerned with the fuel gauge.....and my obc will say when im empty that i have like 30 liters left....WTF!!!! lol
      • accident
        • 7303
        The OBC isnt very acurate. Please explain your fuel gauge issues better.
        • e30power7931
          • Jan 2009
          • 20
          when i fill up the gauge goes to full. when the low fuel light comes on i am at half a tank and the range meter usually says about 155 miles to go but falls every few feet and also when i fill up it will say about 450+ miles which i know is very unaccurate
          • accident
            • 7303
            how do you know you're at 1/2 tank?
            • e30power7931
              • Jan 2009
              • 20
              that is what my gauge is displaying
              • accident
                • 7303
                So when the gauge gets to 1/2 the gas light comes on?
                • e30power7931
                  • Jan 2009
                  • 20
                  yeah
                  • accident
                    • 7303
                    have you tried replacing the whole cluster? the SI Board or the rest of the electronics could be bad.
                    • Jean
                      • 18228
                      Do you have correct cluster or sender in your car? this happens if you have a late cluster in an early car. Fuel gauge will not read correctly.
                      The "Empty fuel" light indicator is triggered when the float in the sender is clost to the bottom, so it's almost an ON/OFF switch where the sender/gauge are dependent on each other to give you correct reading.
                      • accident
                        • 7303
                        Jean, would the gas light turn on at 1/2 tank with a late cluster in an early car? From what he's saying it seems like the needle itself is working fine, but the light is wonky.
                        • e30power7931
                          • Jan 2009
                          • 20
                          i have replaced the cluster 3 times 2 times with 87 model clusters and my current one is from an early 88 cuz the tach went bad....in all of them the gauge never worked and i put in the correct sender all 5 times i have tried.....im thinkin about givin up and sayin ive done all i can all we can do now is hope lol
                          • accident
                            • 7303
                            Ecu?
                            • Jean
                              • 18228
                              According to realoem your car has one fuel level sender, correct? http://www.realoem.com/bmw/showparts...46&hg=16&fg=05
                              You can do the following test:
                              a) disconnect the wiring from the sender unit, one of the 3 wires activates the dummy light, and another is for the gauge, 3rd is ground. when you short one, the light comes on. test it.
                              b) remove the sender and place it in a bottle of water or any other liquid while moving it up and down to simulate the amount of gas in the tank. measure the resistance with a DMM
                              c) replace the sender with a variable resistor and see how the gauge behaves, does it sweep the full empty-to-full rotation? you'll need to look up what resistance your gauge needs.
                              I've done this on my early car, IIRC the range was 4ohms to 70-80ohms for the sender.
