fuel gauge PLEASE HELP!!!
  • e30power7931
    • Jan 2009
    • 20
    yeah we have done all these test but nothing has worked....im thinkin just say f it and give up lol
    • Jean
      • 18228
      What do you mean nothing worked...what were the results? Depending on the results you can deduct what the problem may be.
      • thereisnoyun
        • Feb 2007
        • 2301
        did you replace both sending unit? the one next to the pump and the one on the other side?
        • e30power7931
          • Jan 2009
          • 20
          i have only one sender. Everytime i replaced gauges or sending units when i would be on emtpy my fuel gauge would be reading half a tank. each thing ive tried has had the same results
          • Jean
            • 18228
            Then you might have a wrong cluster or coding plug in your car. I would check with another member who has the same model/year car as you that...
            • e30power7931
              • Jan 2009
              • 20
              ok thanks guys
              • Slick92GS-R
                • Apr 2005
                • 662
                i have this same problem ....i fill the tank (13+gallons)..needle shows full, my odo/trip doesn't work, so i don't know how many miles driven but when needle gets to half.. fuel light comes on.. i've figured the light is correct & the gauge is wrong ..
                1. while at an HPDE w fuel light was on, i got bad hesitation on a long right hander. (late in the day after 3 sessions)
                2. i was at an auto cross fuel light on.. hesitation on quick right left combo (last run of the day)
                3. i ran the fuck out of gas one day, light blazing, half tank showing
                i have 87 325e that i've swapped in a 325is cluster.. my old original cluster has Si batteries woes..
                --Hayden--
                '87 325 coupe- Trak Rat
                '93 318is- 4cyl's of fury
                '92 Integra GS-R--yeah, its fast..
                www.G2IC.com
