Haunted Lighting
  • Collin
    • 1736
    Haunted Lighting
    Yesterday I finished swapping my front diving board for a PB, and noticed the turns were a bit funky.
    Driver side would blink when I hit the lever, but would not light steady when I wasn't turning. The passenger side works fine.
    Driving home from the shop my warning light for all the lights in the back came on, lic. plate lights, brake lights, rear lights all went out. I checked and verified the brake lights were working, but the check lights were right about everything else. Then my gauge cluster went dark.
    Can anyone think of anything I may have knocked loose while splicing the new connectors for the PB turns? Something that would affect the complete opposite side of the car, and the interior as well.
    The Keystone Killers
    With 73k+ post, you'd think he'd have learned a little about life.
  • asubimmer
    • 6482
    sounds like a bad connection, splice etc, that caused a fuse or the headlight switch to blow. Could be countless things though. Thats the fun of wiring :)
    • Collin
      • 1736
      I checked all the fuses with a test light, I'll be going over power and grounds tomorrow.
      • Collin
        • 1736
        Connector 103 under the steering column was lose. Problem solved.
        I don't know how it became lose, as the lights all worked fine before the swap. Oh well.
