The lock on my driver's door will actuate the central locking only if I turn the key to the 3 o'clock "double-lock" position. I can turn the key back and forth no problem. Anybody had this issue?
Driver's Door Lock
Tags: None
So, if you turn the key 45 degrees, what happens?
If there is any reluctancy, I'd say a lock cylinder might be the culprit.- Trey
E90 325i/6 (ZSP, ZPP, ZCW)
E36 325i sedan
E30 325i sedan
Volvo 945T -
The spring on the lock that actuates the regular lock mechanism is screwed. You either need a new lock assembly
Or just put in a key less and forget about the lock cylinder.
http://forums.bimmerforums.com/forum...d.php?t=881484
Part Number:
51-21-9-061-343
Door Lock Repair Kit Left NOTE: Only for cars with central locking.
Manufacturer: GENUINE BMW
Application: 325, e, es from 09/84 E30 325i, is E30 325iC, iX E301989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.Comment
