antenna hole plug???
  • Eric
    • 5141
    I removed the antenna, where can i get something to plug it?
    there is no Home depot in germany, so i need something specific.
    thanks
  • Stephen
    Шлем ишака
    • 10774
    i think you can use a body cap out of an e46, or something. I got mine off a freind, but thats where he said they come from
    • Brian 89 325i
      • 1450
      So say I wanted to remove the antenna and then still have a radio, are there other internal ones?
      • Infamouscrew02
        • 131
        Interested in this mod also....
        • Stephen
          Шлем ишака
          • 10774
          I've heard people using the rear defroster, but i haven't done it.
          • TexasTerp
            • Jan 2009
            • 3541
            This is one of the mods I'm doing on my car right now. Yes there are internal antennas you can use, this is the one I bought (UA200):
            As far as plugging the hole, you could either try and find a cap or get a shop to weld a metal plug in that spot (or do it yourself). I'm going to be getting a new paint job in a couple months so I'm just going to have it welded shut.
            stephenbrody.com
            • AndrewBird
              The Mad Scientist
              • 11898
              If you don't want to paint, you might try a plastic plug like this:
              You can order them here:
              Just measure the size of the hole and buy the corresponding plug. If you have to, drill the hole out to the next size plug that fits. I would also use a little bit of silicon sealant under it to keep out the water. You could even paint it body color if you wanted.
              • TexasTerp
                • Jan 2009
                • 3541
                ^^ Good alternative to welding. Personally I like the more finished look by welding it shut BUT this does leave the option open to return to the oem antenna or upgrade to the z3
                stephenbrody.com
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Exactly. And not everyone wants to have to paint their car afterwards.
                  • accident
                    • 7303
                    Could always get the M3 style antenna...
                    Moral of this story?
