E30 fuel guage
  • rwtags
    • Aug 2018
    • 208
    E30 fuel guage
    I am trying to diagnosis why my fuel guage is pegged to full. On start up it pegs to full. Disconnecting both fuel senders the fuel guage does not change. I have tested the resistance and I think the where both good, but disconnecting both of the senders throws me for a loop. According to the ETM, it shows the 65ohms should show full, and if there is no reistance it should show empty? Am I missing something?
    I have tightened the nut on the back of the odometer and stripped and reflowed all solder joints for the c2 connector, I am just thinking I cannot have a fuel gauge work correctly.
    Car is a 91 325ix.
  • george graves
    • 20003
    I'd look for a short to ground on one of the sensor wires. Somewhere it rubs on the tank? Or along the body. I don't recall what the gauge is suspse to show at full. If it's zero ohms, or very low, that would be the ticket.
    Originally posted by Matt-B
    • Gregs///M
      • Mar 2012
      • 2459
      Yeah George is right, if one of the fuel tank wires is shorted to ground, the gauge will read full hot.
      If the gauge or the main circuit board inside the cluster has failed, it will show full hot.
      There is no nut behind the odometer, only one behind the fuel gauge and one behind the temp gauge.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • rwtags
        • Aug 2018
        • 208
        Does anyone know how the wiring is? Does it originate on the passenger side and go down the passenger side? I was to just one side and see if I just need to run a new wire from driver's side to passenger side.
        I know the layout from ETM, but I don't know where the cables are in the car. Or how I should just the terminals so I can figure out where the short to ground is.
        • george graves
          • 20003
          IIRC it's the passenger side.
          • rwtags
            • Aug 2018
            • 208
            I will report back when i get some time
