The driver rear door lock actuator on my 91 318i is not working anymore, I haven't taken a look inside the door yet. I was wondering if you guys had any tips or tricks that I should know about before I take the door apart, I looked online for a bit but I couldn't find any info on e30 rear door actuators. I did see some stuff online about the rear actuators being vacuum controlled but I am not sure, vacuum control actuators sound kind of weird since the fronts are not. Anyways, I come here for some advice and or guidance for this task.
1991 318i Rear Door Actuator
Tags: None
I had to fix the window on the same door with the bad actuator so I just decided to tackle both at the same time. It was easy to figure out once you are in there.First e30 - 1991 318i 4 door
