Can someone tell me if I installed this push rod for my top cover correctly. It put a hole in the top and ultimately got stuck on the top to the point where I couldn't open the cover. Just wondering if something does not look right with the rod. Appreciate any pictures of what other cars look like. For whatever reason I have had a really hard time finding pictures of this mechanism. Probably because most e30s have switched to manual.
Top Cover Push Rod gets stuck on top
Check info here. I think your lid motor is in the wrong position
Last edited by bradnic; 12-19-2023, 09:11 PM.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts. -
The rod needs be twisted 180 degrees. The concave end is facing the interior of the compartment which touches the top. It also creates a weird angle on the anchor ball which causes the rod to pop off the ball/lever as your raise and lower the lid.1992 325i Convertible
nadodude111 is correct. didn't have my car nearby when I replied. just adjust the coupling on the rod. the link I sent you includes the top adjustment instructions with illustrations.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts.Comment
