Vert trunk shocks
  • reelizmpro
    • 9558
    Vert trunk shocks
    I understand early verts had 1 300N shock while later models had 2 150N shocks. My question is...can I use a single 300N shock on a late model?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
  • B Randon
    • 2569
    not to sure but i have some from late model if you need them
    • TexasTerp
      • Jan 2009
      • 3541
      I believe that you may need some reinforcement for the bracket that connects the shock to the body.
      I'm planning on modifying my early model couple chassis to handle the late model Dual 150N shock setup.
      stephenbrody.com
      • reelizmpro
        • 9558
        How much u lookin to get?
        88 M3 - LACHSSILBER
        • reelizmpro
          • 9558
          Okay, just to update since I found little info on the topic online...The trunk shocks are 100% interchangeable. The only difference is the early vert upto 4/89 production uses a single 300N shock while the later models used two 150N shocks. Why the change? I'm not sure. Here are my thoughts about the dual shock setup. 150N shocks are 1/2 as strong as 300N but there's two of them for even support but this means they are more expensive. Weak 150N shocks are already borderline since the vert trunklid is heavy especially if you have a spoiler. Long story short. I think it's best to find used 300N shocks. It may be too weak for a single shock setup but if you use two, it'll be perfect for a dual shock setup provided they aren't completely blown. They should last longer as well. If you buy two 150N shocks and one gets weak over the years, the single good 150N shock won't be enough to keep the trunk lid open.
          88 M3 - LACHSSILBER
          • e30trooper
            • 11576
            i have a 300n since mines a early , works great!
            • Cha Ching
              • 1668
              Barry, this is good to know since I just replaced my M-Tech trunk shocks and now they don't seem to be able to lift the trunk open completely! Once I fully open the trunk by hand, it stays open, but it doesn't "pop" open under it's own power. I couldn't figure out why, until I read this post.
              Thing is, I cannot remember if I replaced only 1 or both shocks! I think it may have been only 1....I hope! Otherwise, my trunk shocks suck!
              • Cabriolet
                • 9620
                barry if i could id use 1 300N and 1 150N, the 2 150Ns really arent enough. if you have a fin or 3rd breaklight
                Much wow
                I hate 4 doors
                • reelizmpro
                  • 9558
                  I experimented yesterday and ended up doing just that. 1 300N and 1 150N both bought used from the junkyard. The 300N worked great on its own but I added the other for extra support. I just pop it and trunk opens up by itself and stays there.
                  88 M3 - LACHSSILBER
                  • ZM Blue Devil
                    • Dec 2006
                    • 13836
                    You can also use e28 hood shock but it won't open fully. Budget part, works well since e28 hoods are heavy.
                    Levent
                    %20levent@gutenparts.com
                    Ladies:
                    • philipabraham
                      • 1
                      Re:
                      Its really great.
                      penegra,forzest
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        So then, you could use a e23 hood shock to open it fully? I have them on my e28 and they open the hood like on a Benz.
                        • mikeedler
                          • 6707
                          the reason for 2 weaker shocks is the 1 300N will push up that left front section/side/corner on the trunk lid after a while. an old 86 I had would not let the trunk lid align for nothing anymore. 2 shocks at half the pressure evens it out.
                          • devon.818
                            • Feb 2011
                            • 2937
                            the dual shocks are better!
                            using the single 300n shock will cause the trunk lid to warp and leak. me, ubernasty, and ill4noreason came to this conclussion when comparing our three verts last summer.
                            when it is compressed it exerts too much force on that one corner. what i did was remove the clips for the shock, then if i needed the trunk open i would hook it up, then un hook it when closing the trunk.
                            my pdr guy even supported this when he was getting the high/low spots out of the turnk
                            • reelizmpro
                              • 9558
                              That makes sense. Didn't know this was an issue, thanks for chiming in guys. I can see how running a single 300N shock would cause that...it's a strong shock. Running two of them shouldn't cause this problem though right? I figured two used 300N's would be weaker than 300N but stronger than new 150N's while being much cheaper.
                              88 M3 - LACHSSILBER
