Convertible Lower Rocker Trim: Install and RFI: "nub" clip part number?
  • phenryiv1
    • Jul 2009
    • 3246
    This weekend I wanted to get my lower rocker side trim installed but I encountered a snag.
    This is one of those areas where RealOEM fails us as convertible owners.
    Here is the page for the body trim:
    http://www.realoem.com/bmw/enUS/show...diagId=51_0760
    It lists needing a quantity of clamp 51131932865 to attach the lower rocker trim. It is missing multiple parts, however. First off, every 'vert that I have ever seen has has a rubber washer behind the clamps. Not hard to remedy, but an omission in RealOEM.
    I went to Home Depot and bought a few bags of rubber washers in 5/16" and 3/8" size. Either one seems to work but I'd to all of them in 3/8" if I had to do it a gain- slightly thicker and it was easier to get the trim to "snap" in place with the clamp installed, yet it was not so thick that it left a gap between the trim and the body.
    Next up I installed the white clips:
    The next part is a more serious omission. The front attachment point of the lower trim is a small "nub" fastener that snaps in the channel in the trim and secures in a grommet in the lower front fender trim.
    I had 1- just 1 out of 4 trim pieces on 2 cars- and used it on the driver's side. It looks like this:
    Not only is the part number not listed, the part itself is not listed. I checked other diagrams and still cannot find reference to the part number.
    I checked the M-Technic page: http://www.realoem.com/bmw/enUS/show...diagId=51_2003
    I checked the fender page: http://www.realoem.com/bmw/enUS/show...diagId=41_0212
    Nothing. Even the grommet is not listed on any page but I have a bag of those from other parts of the car.
    Also, the trim (which did not come on my car so I had to buy it used from a forum member) has a weird rubber section right in the channel where the nub clip should go.
    If I did not know better I'd say that they had updated the design to not require the nub clip but both this '89 and my late ('92) parts car have the same grommet & nub clip mounting mechanism and the hole in the lower body/fender is too large to accept one of the white clips - only a grommet & nub configuration will work.
    I was able to remove the rubber part with needle nose pliers:
    With the nub clip installed on the driver's side I installed the trim:
    Still trying to locate a clip for the passenger side before I install that trim.
    So this begs the question: What is the part number for the "nub" clip?
    And does anyone have ONE that they would be willing to come off of?
    Patrick Henry
  • phenryiv1
    • Jul 2009
    • 3246
    Bump...
    NOTHING from anyone on the part number for that clip?
    Patrick Henry
    • JasonC
      Site Manager
      • 14451
      Would the black clip be part of the long trim piece? That's why it is not showing up separate in the diagrams? I'm just taking a wild guess.
      1992 BMW 325iC
      1978 Chevrolet Monte Carlo
      • jeffnhiscars
        • Jun 2011
        • 6011
        I bought a bag (Kit) with all 10 (I think it was 10) clips. I don't think it was from BMW but I will try to find the invoice and the source.
        Alice the Time Capsule
        • phenryiv1
          • Jul 2009
          • 3246
          Anything is possible, at this point. I have 3 (used) trim pieces and none of them had the clip and I have a parts car without trim installed that had the piece in the body. But it is entirely possible that the trim comes with the initial fastener already installed.
          Patrick Henry
          • phenryiv1
            • Jul 2009
            • 3246
            Let me know if it has one of those, and if so from where you purchased it.
            Patrick Henry
            • KIRIEIW
              • Dec 2012
              • 3385
              Bump I need that clip part # too. Maybe the parts guy at work will figure out the part number otherwise.
              1992 e34 Touring- S50 Swap
              1992 325i-S50 Swap (SOLD)
              1991
              • phenryiv1
                • Jul 2009
                • 3246
                That nub is a part of the whole trim piece. The location (one end or the other) is what determines whether the part is a "left" or a "right" trim piece.
                The "nub" is not available as a independent piece.
                I found that out the hard way.
                Patrick Henry
