Hardtop rattle
  • allen_t
    • Feb 2014
    • 552
    Hardtop rattle
    Just installed my hardtop and I tightened both ends, still rattles on the rear left side. Anyone else have this issue or know a solution?
    http://www.DeluxeCarStorage.com
    87 325ic - Early ACS Tribute
    90 325i MT2 - R.I.P
    Seller Feedback: http://www.r3vlimited.com/board/showthread.php?t=380908
  • Mwishlist
    • Jul 2013
    • 505
    How tight is it or how hard was it to snug down? You can adjust how tight it sits down on the car. If it's nice and snug on both sides then I don't have an answer for you. But I would imagine the rear left side needs to be adjusted to be tighter.
    Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
    • fight4life28
      • Apr 2014
      • 821
      Mines does the same thing, switched it from my red late model to my early model and it rattles a bit over bumps....I was wondering the same thing as the op
      • jeffnhiscars
        • Jun 2011
        • 6011
        If you have the tool you can tighten the star wheel with the top installed although I'd recommend backing off the latches first to avoid breaking anything. BMW charges $28 for a silly stamped tool but it works.
        Alice the Time Capsule
        • allen_t
          • Feb 2014
          • 552
          Ill check on that! Im assuming this is whats causing my defroster to not come on either. All the leads look clean and straight.
          90 325i MT2 - R.I.P
          • jeffnhiscars
            • Jun 2011
            • 6011
            There's a push terminal on the drivers side plastic socket where the top locks down. That's where the top get battery pos so yes, a loose lock down pin can effect the defroster.
            There's also a rear blower disable micro switch near the hinge on the drivers side that enables the defroster circuit in the glass. Iirc that connector is similar to a brake pad wear sensor. When I replaced my soft top I neglected to reconnect that since I didn't know it existed.
            • rcsoundn1
              • Nov 2012
              • 3361
              Im jelous of your hardtops! Good info though
              • allen_t
                • Feb 2014
                • 552
                Thanks for the info, it looks like the height of the nuts on the actual pins were different on the drivers side. I adjusted that with the hardtop unbolted from the body and now it sits tight. Bring on the winter!
                90 325i MT2 - R.I.P
