Help!! Subframe bushings broke off in car!
  • gart
    • Jul 2012
    • 295
    As the title states. Got the subframe out but the tops the aluminum sleeves in both bushings broke off in the mounting holes. Anybody have a trick to getting these out?
    I also pushed both subframe bolts up into the body not knowing that cabrios are not accessible from under the rear seat. Can I get to these through the quarters if I pull the rear cards. Thanks for the help in advance!!
    89 325 cabrio in progress m52tub28 swap
    99 540it
    86 Volvo 240 wagon
    99 Cherokee
    13 Passat
  • gart
    • Jul 2012
    • 295
    Someone's got to have been through this before.
    99 540it
    86 Volvo 240 wagon
    99 Cherokee
    13 Passat
    • mr2peak
      • 2388
      Oh yeah I just went through this. Try the lag bolt method. If that fails, which it did in my case, you will need an air chisel. It's a huge pain in the ass, especially in a vert.
      I used a ton on anti-size on the new ones!
      Drive it hard. Maintain it well.
      A Topless Memorandum
      • TimeMachinE30
        • Jun 2014
        • 3749
        What method did you use to get you in this predicament?
        ACS S3 Build / Dinan 5 E34
        • gart
          • Jul 2012
          • 295
          ^ I just dropped the subframe and where the inner sleeves of the busings go into the body is where they broke. Guessing it's just a tight fit and the aluminum to steel didn't help either. Lag bolt method didn't work for me. I ended up drilling and chiseling them out. It was a pita but I got them and will be finishing up the wheel bearings tonight or tomorrow. Looks like I can access the bolts that I pushed up out of the way once I get the rear cards pulled.
          99 540it
          86 Volvo 240 wagon
          99 Cherokee
          13 Passat
          • mr2peak
            • 2388
            Yup you can get to them. You just can't hammer anything down onto them because of the bodywork
            • gart
              • Jul 2012
              • 295
              I got to them today. Thank god I don't have giant hands.
              99 540it
              86 Volvo 240 wagon
              99 Cherokee
              13 Passat
              • DoneRightBimmer
                • May 2012
                • 158
                I had thesame issue when i pulled my subframe. Ended up drilling it out luckily the metal was relatively soft.
                • mikerob97
                  • Jul 2010
                  • 140
                  [/QUOTE] I also pushed both subframe bolts up into the body not knowing that cabrios are not accessible from under the rear seat. Can I get to these through the quarters if I pull the rear cards. Thanks for the help in advance!![/QUOTE]
                  This sentence caught my eye...so on cabriolets, you can't remove the rear seat, then push the large sub-frame mounting bolts up through the floor board like you can with the coupes and sedans? I did not know this...Please confirm.
                  Mike
                  Cary, NC
                  Current Rides
                  1991 325iC - For Sale
                  2006 M3 Cabriolet
                  Past Rides
                  2000 323i Touring - Daily Driver
                  1994 325is (S50) - Fast Car
                  1998 Z3 - Fun Car
                  1986 325e (i engine conversion)
                  1969 Mustang Mach 1
                  • gart
                    • Jul 2012
                    • 295
                    ^ you can push them up they just come up into the quarters so you need to remove the whole rear seat, and rear door cards to get to them. There is a acces hole I could barely fit my hand in to get the bolts retrieved and back in their place. I'm 5'7" and 125lbs so if you're a big guy you might have a rough time.
                    99 540it
                    86 Volvo 240 wagon
                    99 Cherokee
                    13 Passat
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      When I did my Cabrio I just pushed the bolts up far enoguh to put a plug in to hold them up without ever going inside the car
                      Alice the Time Capsule
                      • Mwishlist
                        • Jul 2013
                        • 505
                        I can't find the original post but I successfully used the lag bolt method on my vert. The trick is you have to buy a 3 or 4 foot steel rod from Lowes and put a bend in it. That way you can just get it down in the hole from the top. Lag bolt screwed into the bushing and several whacks from a BFH and you are golden.
                        Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
