M3 spring on vert
  • mazzo
    • Jul 2014
    • 264
    M3 spring on vert
    I have using a set of H&R on my vert, and with my set of 16" style 4 the rear is a little too low for my taste. Does OEM M3 spring has less drop than the H&R at the rear?
    Current:
    '88 325ic Silver 5sp
    '17 Subaru Outback 3.6R
    Past:
    '14 Rav4 EV (with tons of torque!)
    '06 325i Black 5sp
    '02 S4 Avant Black 6sp
    '00 Boxster Silver 5sp
    '98 New Bettle Yellow 5sp
  • sonomabimmers
    • Dec 2015
    • 802
    sub'd for an answer I'm looking for same question
    i love bmws
    • reelizmpro
      • 9556
      I would say yes. M tech springs are about an inch lower on a sedan/coupe. The vert rear is heavier and with the lower arch the rear will always be lower unless you raise it with spring pads. The rear is rated at 300lbs progressive.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
