I recently installed a new top following all instructions to a T. I watched three videos etc. The rear portion does not meet up with the boot/seal properly. I am left with a 1/2 gap where the rear seal should meet the boot. Any help would be appreciated.
Convertible top adjustment
there are a bunch of shims in various locations under the top frame in the boot well. i suggest taking some of the shims out from under the frame.
there are two bolts that go vertically through the top frame and into the boot well on each side and one that is horizontal in the forward direction. play around with the shims in those areas and hopefully you can get it to line up better.sigpic
Gigitty Gigitty!!!!
12 135i M sport cabrio grey/black -
The forward shims are slotted and can be removed by just loosening all 6 bolts. The bottom shims have holes so decide before hand how much you want to lower the top, then remove it to access the shims. Don't forget to unhook the micros witch connector firstSeat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
