Here's a shot of where they go. Its where you bolt the top to the body so if you flip up the back window its right there
The trick is dealing with the spring clip on the ball joint since its not very accessible. I use a metal bbq skewer to pop it off. Here's the new one going in. Put a dab of grease in the hole so the clip stays put, use a big screw driver to press the socket on to the ball, then snap the new clip around the neck of the socket.
The plastic sleeve is easy
