X Brace for street only E30
  • mjposner
    • Aug 2015
    • 169
    So I have a totally stock E30. It is a week-end car, and I am debatiung whether to add X brace. My friend added to his no gone vert, and said it was a great edition. My tire guy (wqho runs a race shop) said its not needed (we have smooth streets in South Florida).
    I am installing a gargastic strut brace (should arrive today).
    Discuss.
    P.S. Why the F do we have a Nazi smile????http://www.r3vlimited.com/board/imag...s/naziskie.gif
  • Mixedbyjairo
    • Sep 2016
    • 103
    Bump
    • exhaust
      • Jun 2015
      • 411
      I loved my Garagistic brace. Really tightened the car up and made a difference. I only took it off because it couldn't clear my exhaust setup after the swap. (Early version, they've since solved that). I plan on getting another one very soon, can't recommend it highly enough.
      • Mixedbyjairo
        • Sep 2016
        • 103
        Did you feel a night and day difference? And where did you feel it the most?
        • exhaust
          • Jun 2015
          • 411
          Maybe not night and day but night to early morning. The front end was noticeably tighter and more controlled, much less cowl shake and overall rattled less
          • fight4life28
            • Apr 2014
            • 821
            Definitely made a difference, having owned a vert with and without one now it would be my number one mod for a vert. I have Race Skid one but works same as the rest. Does sit low sooo take care of when you are lowering your car.
            • Poorhouse
              • Nov 2016
              • 497
              I've got one and it is absolutely worth the money.
              Skip the strut brace and get the x brace.
              1991 318iC
              1989 325i Field Rescue
              • mr2peak
                • 2388
                I like mine
                Drive it hard. Maintain it well.
                A Topless Memorandum
                • Mwishlist
                  • Jul 2013
                  • 505
                  This right here. It definitely makes a difference. It doesn't make it into a race car but the front end is much more controlled and overall the car just feels more solid / less rattles cowl shake. So much so that I'm probably going to get a brace for the rear eventually.
                  Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
                  • Mixedbyjairo
                    • Sep 2016
                    • 103
                    What brace is made for the rear ?
                    • Bearmw
                      • 1323
                      ^The butt strut or something similar. Unfortunately there are not a lot of people who have one on on an E30 so there isn't much feedback about them. I would prefer to just run stiffer subframe bushings myself due to the loss of ground clearance with a rear bar.
                      Many people have an X brace of some type and the feedback is very positive. I have a steel Mason X brace and like it. It was pricey but it made a noticeable difference.
                      • e30rapidic
                        • 2167
                        Will this cross brace work with an S50?
                        '87 325ic, powered by S50.
                        • Mixedbyjairo
                          • Sep 2016
                          • 103
                          I'm confused on how to install a butt strut on a vert , cause of where the shock mounts are
                          • Mwishlist
                            • Jul 2013
                            • 505
                            Like this one here:
                            • Mixedbyjairo
                              • Sep 2016
                              • 103
                              Do you feel more of the engine vibration. Since the xbrace bolts on to the Sub frame ?
