"Pull Strap" in place of tonneau cover release handle?
  • phenryiv1
    • Jul 2009
    • 3246
    As all manual-top convertible owners know, the rear release handle foir the tonneau cover is just a door handle flipped over (with a few extra bits for the cables). I am not really happy with how much the handle flexes when I pull the release, always feeling like it is a slightly overzealous pull away from breaking.
    I saw these RS-style pull straps used for door pulls:
    Any thoughts on a similar approach for the top release?
    Patrick Henry
  • Mike36
    • 1078
    This is pretty cool. Took me a few hours to adjust the tension after I completed my conversion but I still sometimes fell like it's going to snap every time I pull it open.
    • Streichholzschächtelchen
      • Jan 2009
      • 1670
      has to be better than zip tyes lol
      Jah bless! :pimp:
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        I like this idea. The flimsy plastic handle has already broken on my once; I think a strap would eliminate this point of failure.
        • IronJoe
          • 2275
          Same. I absolutely hate that handle in the back, I've already replaced it and just about broken it again.
          '89 Schwarz E30 M3 Cabriolet Build
          • Das Delfin
            • Sep 2014
            • 2293
            You can adjust the tension so it has better action. Mine fell apart once and I replaced it; it's been fine since, and that was a few years ago.
            But I like the idea.. have it match your interior and make it classy :D
            • phenryiv1
              • Jul 2009
              • 3246
              I will probably give this a shot in the next few weeks.
              Patrick Henry
              • TimeMachinE30
                • Jun 2014
                • 3749
                Are the handles breaking just a result of a top needing adjusted?
                ACS S3 Build / Dinan 5 E34
                • phenryiv1
                  • Jul 2009
                  • 3246
                  My guess would be yes but mine has never broken. My top has a lot of tension on the cover when the cover is closed so I have to pull pretty hard to get the cover to release. When the top is up and I am lowering/stowing it the tension on the handle is minimal. It only happens when releasing the cover when the top is stowed.
                  Patrick Henry
                  • TimeMachinE30
                    • Jun 2014
                    • 3749
                    Mine, too, is testing the limits of the handle when pipping the cover.
                    • phenryiv1
                      • Jul 2009
                      • 3246
                      That tension is not really a function of top adjustments. I don't know what else can be done to lessen the tension on the tonneau other than to get a top that folds flatter.
                      Patrick Henry
                      • IronJoe
                        • 2275
                        I tried spraying some lubricant through the cables and it may have helped slightly.
                        • Das Delfin
                          • Sep 2014
                          • 2293
                          that means the tension on the handle is too great. This could lead to a failure if the constant stress weakens the handle over time.
                          This is the adjuster.
                          • parkerbink
                            • Jun 2004
                            • 10137
                            Which side is that on?
                            • phenryiv1
                              • Jul 2009
                              • 3246
                              http://i.imgur.com/1BmqL.jpg?1
                              Question (not a challenge/argument): since the tension is only high/concerning when the top is stowed (not when releasing the tonneau to stop the top), is it still the tension cables?
                              I (maybe incorrectly) thought it was the top storage pushing up on the top that was making the release right as opposed to mis-adjustment of the cables since it is only tight when the top is stowed.
                              Patrick Henry
