Manual Top Tonneau Cover Release Handle not working
  • Aleman
    • Mar 2012
    • 1611
    Anyone know how I might be able to open the tonneau cover without using the handle in the rear quarter behind the driver seat? When I pull the release handle, there is resistance, but the tonneau won't release & pop-up.
    Probably a screw is loose or a latch needs lube. Would I be able to open it from the trunk or behind the interior panel somehow?
    Searches have turned up nada.
    Thanks!
    R135 /// 1990 Alpinweiß II 325is
    └┼┼┘ /// 1993 Black/Black Convertible (sold)
    ..24
  • yosh
    • Aug 2009
    • 350
    You gotta run your fingers under the cover and push that lever to fully release the cover, kind of like a hood latch release on a regular car.
    Sent from my VS985 4G using Tapatalk
    • Aleman
      • Mar 2012
      • 1611
      Solved. I just had to tap on the cover a little bit while pulling up on it. It eventually popped loose. Sprayed from lithium grease on the latches, and it works great now.
      ..24
      • PTUHPTUH
        • Dec 2016
        • 12
        I seem to be facing the same problem, I pull on the latch behind the driver's seat and nothing. I'm worried if I pull any harder I'll break it right off. Can you elaborate on how you solved the problem?
        Greatly appreciated,
        PTUH
        • DRVN2WN
          • Jan 2017
          • 39
          Does the handle move or is it stuck?
          drvn2wn
          • PTUHPTUH
            • Dec 2016
            • 12
            The handle moves but nothing is unlocking or moving... any help?
            • cspec
              • Apr 2017
              • 182
              Can you hear any movement of the wires?
