Hardtop window issues
  • cspec
    • Apr 2017
    • 182
    Didn't have this issue when I had my softtop, it only started appearing after I put my hardtop on.
    When I roll up my front windows, it seems to get caught in the rubber seal on the back window. I know that we can adjust the angle of the front window, I've done it before, but has this happened to anyone else?
    Is the hardtop kind of flexing something...?
  • spare
    • Jan 2016
    • 42
    In my case, the PO had aligned the windows to an old original soft top that was misaligned and the tension straps were shot. The hardtop is the template and I realigned the windows to that and put them back to a what I believe is close to stock.
    Sent from my Pixel XL using Tapatalk
    • cspec
      • Apr 2017
      • 182
      Thanks for the reply, should I re-adjust my windows to my hardtop? Would it mess up my soft-top afterward?
      • jeffnhiscars
        • Jun 2011
        • 6011
        I'm thinking that since the soft top can be repositioned by adding or removing shims whereas the hard top sits where it sits, you may want to adjust the windows to the hard top, then reposition the soft top to the windows...as long as it doesn't leak.
        I actually close my doors by GENTLY pushing the upper corner of the glass just enough so it slips under the seals.
        Alice the Time Capsule
        • cspec
          • Apr 2017
          • 182
          I have never adjusted my soft top before, but I will make it my next weekend project! I always thought there was only one location to add shims? I noticed on mine it is stacked with quite a few.
