Vert Rear Bottom Top Adjustment..
  • rustneversleeps
    • Aug 2016
    • 132
    I have 88 and the rear bottom top doesn't sit flush with the cover about 1/4 or 1/2" high.
    I like to bring the rear down on mine would i have to remove some shims or is there more to it then that...
    the bottom of the top is sitting high and like to put it lower flush to the cover like i see on other vert.
    Maybe my top shrunk
    but doing that would it be to tight to close...
  • jeffnhiscars
    • Jun 2011
    • 6011
    You can drop it down a bit by removing some of the horizontal shims although you do have to completely remove the top as those shims have holes not slots. Watch your windows at the seals since any change in top position may demand a window adjustment.
    Its whack-a-mole getting it dialed in
    Alice the Time Capsule
    • rustneversleeps
      • Aug 2016
      • 132
      Thanks man I'll take a closer look to see if shims the problem..
      Also by removing some shims wouldn't it make it tighter to close the top cause i really have to pull the handles just to close any ways will look and see will post pics...
      And not from Photofawk-it either...lol
