How exactly does the front convertible top seal secure?
  • BaltimoreBimmer
    • Apr 2016
    • 307
    Hey guys,
    My front seal is absolutely ravaged. I am going to be replacing it. I have adjusted the windows but the part of the seal that extends to the sides have actual tears in them. I understand how the sides secure into the rails (there are little grooves that hold it on either side). However I can't figure out how the front section sticks to the top. My PO(s) clearly had issues with leaks as there is tons and tons of goop/sealant across the front between the seal and the top. Is there any sort of adhesive that is supposed to go with this front seal install?
    It appears there is simply a lip that the front section slides into but I want to see if anyone else has some input here. Also I am not positive what parts number 21 is on this top seal realoem diagram. Will I need to replace that? Looking at my vert I am not seeing where it goes.
    https://www.realoem.com/bmw/enUS/sho...diagId=54_0162
    If pictures would help, I can upload some.
  • bradnic
    • Jul 2012
    • 3554
    Part 21 is not a seal. It’s the felt+rubber piece that goes along the top of the window frame.
    The front seal is part 1 in the diagram, and wraps around to both sides. It’s crazy expensive - $600+ when I got mine a while back.
    The front seal is glued in place - check out the 3 part bmw convertible top videos on YouTube for details on installation
    Part 1 is here https://m.youtube.com/watch?v=M0G6FsYeY5g
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
    • BaltimoreBimmer
      • Apr 2016
      • 307
      This is great information, thanks! I picked up the front seal already but I had no idea it needed to be sealed in place. Makes a lot of sense though. Pretty nice as you can the see the name (Sikahflex-221) of the sealing compound used in the video.
      • BaltimoreBimmer
        • Apr 2016
        • 307
        that video says so let the sealant dry with the top in its relaxed unsecured state. Many other guides I have seen all recommend laying the sealant in and then latching the roof and letting it sit for 24 hours (cleaning off any excess that comes out when you latch it)
        the latter seems like a better idea. Any input?
        *e: went with the latter. Now we wait. According to the video you should wait 24 hours without touching it. According to the label on the same stuff used in the video it doesn't fully cure for............7 days
        • bradnic
          • Jul 2012
          • 3554
          I’d wait as long as you can. Re-gluing that front piece without aligment problems might be hard, and deintitely messy
          HOWTOs:
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
