Replacement Top Options
  • Poorhouse
    • Nov 2016
    • 497
    We've had a few threads about this that have petered out.
    Has anyone found a replacement top option with a zip in back window?
    IIRC all the current offerings have sewn in windows.
    Assuming no zip in option, any opinions on the best of what is out there?
    I've got my car scheduled into the upholstery shop in about a month. Need to get a top ordered.
    1991 318iC
    1989 325i Field Rescue
  • Poorhouse
    • Nov 2016
    • 497
    No opinions on tops?
    1991 318iC
    • bradnic
      • Jul 2012
      • 3551
      I have not found one. I actually spent big $$$ on an OEM top a couple of years ago.. no zip out window.
      @jeffnhiscars found a source for the actual window though. I suppose you could take an aftermarket top and add the needed zipper.. I do have a brand new aftermarket German cloth top available if anyone is interested.
      HOWTOs:
      DB vert plastic bumpers
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • Poorhouse
        • Nov 2016
        • 497
        Saw your debacle with the OEM top.
        I'm curious if there is any difference between the $275 am tops and the $750 ones?
        Seems there is often one supplier churning out parts that got put into different boxes with much different prices.
        Sent you a PM about the top.
        1991 318iC
        • Cptcarisma
          • Jan 2011
          • 466
          Hey Poorhouse,
          I’d strongly suggest replacing your tensioner straps when doing new top.
          Seems to keep the fit/finish nice and tight. Going back and doing it afterwards is a costly pain.
          Well worth the extra couple hundred bucks.
          Good Luck!
          CAPP.... :-)
          • Poorhouse
            • Nov 2016
            • 497
            Thanks!
            1991 318iC
