The Cabrio Suspension Thread
This is a sticky topic.
  • ddogstyle1
    • Jul 2009
    • 48
    #166
    so wil the 318i non convertible lowering kit work for the 318 convertible?
    • 3bvert
      • 1032
      #167
      eibaechs worked on my 318ic just fine
      • aworthybrother
        • May 2007
        • 899
        #168
        Not sure. Rear of cabrio is heavier than non-cabrio
        • aworthybrother
          • May 2007
          • 899
          #169
          Looks good! Is this an eibach springs for non-cabrio?
          • ddogstyle1
            • Jul 2009
            • 48
            #170
            what kinda of shocks and struts did u use.
            • Wishno87
              • 6025
              #171
              Originally posted by aworthybrother
              M3 springs = $100
              Bilstein Touring Shocks = $220
              I would prefer Bilsteins touring over Tokico.
              I actually have M3 springs and Bilstein Touring Shocks waiing to be installed on my cabrio. I will let you know how it goes when completed.
              You get around to this yet?
              • aworthybrother
                • May 2007
                • 899
                #172
                aboout 3/4 to n inch drop.
                Not the best before and after pic but here it is. I think would be a great set up for a 325 instead of 318. I thinking of cutting a coil in the front...
                Before pic is with the top up
                After pic is with the top down
                • mattdk318i
                  • Jun 2006
                  • 3953
                  #173
                  Got a set of H&R Sport Cabrio springs up for sale for 170 shipped
                  • aworthybrother
                    • May 2007
                    • 899
                    #174
                    Please specify if 325 or 318 cabrio springs?
                    • mattdk318i
                      • Jun 2006
                      • 3953
                      #175
                      325
                      • Wishno87
                        • 6025
                        #176
                        How do you feel about the shocks? Satisfied?
                        • Hey-U
                          • Mar 2008
                          • 560
                          #177
                          Fronts will work for sure. The rear will likely sit a little lower that original spec. The back end of the vert is quite a bit heavier. The rear of the 325 and 318 vert is the same so rear vert springs are interchangable. Eibach Pro kit front springs are:
                          BMW spring 325 305mm 318 279mm
                          12.5 mm/21 Newton 12mm 20 Newton
                          or 119 lb per ft or 114 lb per ft
                          Not sure of the specs for the rear but if you contact Eibach tech department they will give you the details.
                          Eibach pro kit for vert pn
                          318ic = 2010.240
                          325ic = 2010.140
                          • vtman05
                            • 86
                            #178
                            Hey can anyone with cab specific H&R springs and bilsteins sport shocks tell me how much camber and toe they have on the rear tires. I have something like -3.5 each side for my DD so I am doing up the whole rear subframe with all new bushing and the IE weld on adjustable toe and camber kits. I want to know if my neg camber is because of wacked bushings or just it is that low.
                            • owenjm
                              • 237
                              #179
                              billy sports
                              I just found e30 billy sports for
                              119.96 front
                              91.73 rear
                              anyone found them for less.
                              the site is importrp.com
                              looking at going with bav auto vert springs and bilstein sports.
                              hope its not to low, s50 pan sits lower than m20
                              • owenjm
                                • 237
                                #180
                                just measured my pan clearance with s50
                                it is 5" stock suspension.
                                going to be close after bav auto's and billy sports
