The Cabrio Suspension Thread
This is a sticky topic.
  • Aerton
    • Oct 2006
    • 729
    #211
    Originally posted by VacMan
    '87 325i cabrio
    I wouldn't change a thing about my suspension besides the dampers. I know some don't like the bavauto springs, but I am very pleased with them. I never have seen what the spring rates are, but I'm sure they're soft, which suits me just fine.
    Just wondering if 3 years later those springs are holing up and you still recommend them?
    WTB-Strut Bar
    • VacMan
      • Apr 2007
      • 2405
      #212
      Originally posted by Aerton
      Just wondering if 3 years late those springs are holing up and you still recommend them?
      LOL hell no. Sold them after owning the car 6 months. It was fine for a DD but horrible when pushed. Running H&R cabrio springs with pads removed and Koni Yellows now. SO much better, especially in transitions. No bottoming out, either.
      • Aerton
        • Oct 2006
        • 729
        #213
        Thank you for that, my buddy has a set of BAV Auto but I will pass.
        WTB-Strut Bar
        • Aerton
          • Oct 2006
          • 729
          #214
          What rear mount do you use or recommend
          So I was looking at the Turner Motorsport page and they have three rear mounts. They have three mounts and don't know if by choosing high performance will that be ok for a convertible or add to noise stiffness etc.
          Comments please.
          WTB-Strut Bar
          • N2MYE30
            • Oct 2007
            • 5536
            #215
            Originally posted by cactusjacks1
            Do you happen to know what size pads? Real OEM lists two, a 5mm & a 10mm. Which ones did you remove? Your stance is one of the nicest I've seen - great work!
            Jack
            I removed both and I think they both added up to 10mm. Thanks for the compliments.
            COTM
            • handysmurf59
              • 335
              #216
              Hi,
              I have a set of H&R sport springs (cabrio spec) and Bilstein sport shocks. I was just wondering if you guys with this setup have had camber related tire problems. So the short version is Do I need to install some camber plates to correct camber for the lowered ride height? Thanks any input is appreciated..
              Jason
              "But the way it deals with bumps and heaves makes you think the shocks are filled with unicorn farts and pixie tears."
              • Cha Ching
                • 1668
                #217
                Anyone running a Boge/Sachs shock + H&R Sport spring set-up?
                • Takeivy21
                  • 58
                  #218
                  Please dont hate me for my complete noob question, but why do the verts have their own specific suspension? Any help thanks!
                  www.rstyleautomotiveperformance.com
                  • treff-7
                    • Sep 2009
                    • 345
                    #219
                    Originally posted by handysmurf59
                    Hi,
                    Jason
                    i have the exact same setup and i do have problems with camber. i have about 2.5 degrees difference between the 2 sides (if i remember correctly). i need to get adjustable plates.
                    • treff-7
                      • Sep 2009
                      • 345
                      #220
                      it doesn't have a roof so the bottom of the car is a lot stronger than the coupe's plus it has the compartment in the back for the top which makes the rear heavier -> weight distribution is different from the coupe and it's more flexible as well because there's no roof to keep it rigid.
                      i hope this helps! ;)
                      • VacMan
                        • Apr 2007
                        • 2405
                        #221
                        Some updated pics of my suspension (H&R sport cabrio-specific springs, Koni adjustables, no spring pads) versus a gutted sedan on H&R Race with spring pads installed. I apologize for the blackberry pics, but you get the idea. Tires are 205/55/15 on 15x7, ET13 wheels.
                        • Cha Ching
                          • 1668
                          #222
                          VacMan, your 'vert is so righteous! Great stance & interior. Where did you source your Koni's? I'd like to get some since everyone seems to run Bilstein with their H&R Sports...
                          • Wishno87
                            • 6025
                            #223
                            VacMan do you think my car would get lower with cab specific sports? I want to update the suspension a bit but i dont want to go higher.
                            • BDK
                              • Jul 2008
                              • 684
                              #224
                              anyone heard anything about Spax Cab Springs mit55/35 drop?
                              • Takeivy21
                                • 58
                                #225
                                So the size and the way the suspension fits is still the same?
