The Cabrio Suspension Thread
This is a sticky topic.
  • treff-7
    • Sep 2009
    • 345
    #226
    Originally posted by Takeivy21
    So the size and the way the suspension fits is still the same?
    the design of the suspension is the same. the only difference is the stiffness of the springs and (maybe) shocks. and the stock ride height is lower as far as i know.
    i thought the size of the body was the same until i swapped my metal bumpers to the plastic ones. on coupes you need to cut the rear one because they are too long for the early style body but on convertibles they fit perfect so there has to be some difference. i never had the chance to compare them side by side.
    • VacMan
      • Apr 2007
      • 2405
      #227
      Originally posted by Cha Ching
      VacMan, your 'vert is so righteous! Great stance & interior. Where did you source your Koni's? I'd like to get some since everyone seems to run Bilstein with their H&R Sports...
      Thanks. Got the Konis nearly new from a bimmerforums member. He sold his entire suspension after he blew an on-ramp and flipped his car into a ditch.
      Originally posted by Wishno87
      VacMan do you think my car would get lower with cab specific sports? I want to update the suspension a bit but i dont want to go higher.
      No, cabrio springs will help the rear, not the front. I'd pull the spring pads, it's worth almost another .5" drop. You can also do the 15mm drop hats that are being sold here as well. Combined they're be over a 1" drop in the front from your current stance (which I think looks good, btw.)
      Yes, springs and shocks/struts are interchangeable as are the mounts. Only the spring and damping rates change. Do realize that the 325 cabrio is the heaviest E30 and definitely needs stiffer rear springs. I started out with non-cabrio springs and I couldn't stand it.
      Early bodies have different rear wheel arches than facelift bodies. Earlier bodies' rear fender arch is higher. All cabrios have the lower arches, which is why plastic bumpers from a facelift car bolt right on even though cabrios didn't get the facelift until mid-'91.
      On an early non-cabrio you have to cut out a section of the rear bumper to get it to fit properly. Writeups on how to do this exist on R3V but I've never needed to do it.
      • Takeivy21
        • 58
        #228
        Ok thanks, thats the info i was looking for, i knew the verts were heavier for obvious reasons, my question really came based off of not seeing any coilovers or spring/damper setup that drop it as low as i would like.
        www.rstyleautomotiveperformance.com
        • handysmurf59
          • 335
          #229
          i have the exact same setup and i do have problems with camber. i have about 2.5 degrees difference between the 2 sides (if i remember correctly). i need to get adjustable plates.
          Thanks for the reply :-D. I will be looking into adjustable camber plates. Does anyone know which ones will correct the 2.5 degrees without bumping the front ride height back up? I really don't have much experence with this so any help would be great.
          "But the way it deals with bumps and heaves makes you think the shocks are filled with unicorn farts and pixie tears."
          • VacMan
            • Apr 2007
            • 2405
            #230
            Any camber plates will help the front. The rears require more work. I know some company has a weld-in kit for the rear with an eccentric for adjusting rear camber but I don't remember who.
            • Cha Ching
              • 1668
              #231
              Wishno, what size wheels are those? 18's?? Looks great!
              • zep06
                • Apr 2007
                • 181
                #232
                any feedback on the h & r touring cup kit for convertibles? looks to be a slightly new product? the drop is the same as the cabrio springs, so i guess it just a matter of how good the shocks are that come with it.
                • Wishno87
                  • 6025
                  #233
                  They are 17X7.5 with 215/40s. Thanks dude!
                  • handysmurf59
                    • 335
                    #234
                    Has anyone removed the front spring pads when they installed their lowering springs? If so, how much of a height difference did it make?
                    Thanks,
                    Jason
                    • aworthybrother
                      • May 2007
                      • 899
                      #235
                      any pic of a 318 cabrio running m3 springs with drophats?
                      • thereisnoyun
                        • Feb 2007
                        • 2301
                        #236
                        spring pads makes such a huge difference, many of the prior post did not show if they kept the spring pads or not. Its also important to note there are 3 thickness of pads for the rear, and I have all three, 9mm, 6mm and 3mm which makes a dramatic difference which one is in.
                        • aworthybrother
                          • May 2007
                          • 899
                          #237
                          does it make any clunking sounds when spring pad are removed in the front?
                          • VacMan
                            • Apr 2007
                            • 2405
                            #238
                            No. You won't notice any difference at all. I do think that there might be a little more vibration transfer versus having them in, but it's negligible.
                            Here's a clearer pic:
                            • Wh33lhop
                              • 11705
                              #239
                              More pics of passenger seat.
                              paint sucks
                              • aworthybrother
                                • May 2007
                                • 899
                                #240
                                Thanks, I always admire your car. Everything looks perfect. Did you get a chance to compare how much height difference - with and w/out pads? Is it really .5 inches from what I've read? Thanks.
