The Cabrio Suspension Thread
This is a sticky topic.
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #361
    At least on my car, the carbio sports road high & stiff, exactly the opposite of what I wanted. Low & smooth is the way to go in a convertible.
    • 5ickride
      • 2922
      #362
      HR Races are pretty stiff from what ive gathered. But def lower. What are you riding on now?
      • N2MYE30
        • Oct 2007
        • 5536
        #363
        try to ignore the angle but focus in on the wheel distance. Both of my cars have coupe H&R sports, with all pads in, and 15mm drophats. There is a difference between models.
        COTM
        • bimmerteck
          • 762
          #364
          Originally posted by bimmerteck
          I am running. . .
          GC coils with 460/650R
          GC Camber Plates
          Shortened Koni SA Shocks
          CG Rear Shock Mounts
          No rear bar/m3 style adjustable links on the front.
          Coming soon modified front struts and rear subframe So I can crank them on down. (they are all the way up in these pics.:D)
          Erik
          UPDATE: Contacted eibach and ordered some tender springs and spacers to be able to run a dual rate setup up front as well as shortening the housings finally. Hopefully this will make the car behave a little better over expansion joints and such at speed without severely compromising handling in the turns, or having to raise the car drastically.
          • 5ickride
            • 2922
            #365
            Correct me if im wrong but the coupe HR sports lower the rear more than Vert HR sports, right? And the front springs are basically the same?
            On your pic, the front of the vert looks lower than the coupe. Engine weight?
            • N2MYE30
              • Oct 2007
              • 5536
              #366
              Originally posted by 5ickride
              Correct me if im wrong but the coupe HR sports lower the rear more than Vert HR sports, right? correct.And the front springs are basically the same? correct.
              Both have M20 (as of right now ;-)) but you are right, the cabrios front is lower (~.5" on wheel arch). Im not sure why but maybe it is the additional structure weight the cabrio contains.
              COTM
                • 37827
                #367
                I've got a pair of Eibach vert specific rear springs if any of you topless people are interested.
                Classic BMW Specialists
                Santa Clarita, CA
                www.BimmerHeads.com
                • e304lyfe
                  • 807
                  #368
                  They are high, but not stiff. They have the same spring rate as h&r sports for a coupe/sedan.
                  I thought you were going with GC coilovers? Linear springs are not going to provide for a smooth/soft ride.
                  correct me if im wrong but the coupe hr sports lower the rear more than vert hr sports, right? correct. And the front springs are basically the same? correct.
                  This is incorrect. The front h&r convertible springs will not lower the car as much as h&r coupe h&r sport springs.
                  • N2MYE30
                    • Oct 2007
                    • 5536
                    #369
                    He stated "basically" and thats what I was going on. If its drastically different, I stand corrected. If you have spring rates to compare the two, id like to see them as it would be beneficial to this thread as well.
                    COTM
                    • e304lyfe
                      • 807
                      #370
                      Spring rates are the same according to the folks at H&R. Difference is the height, for both front and rear. H&R convertible springs are the same as H&R iX springs.
                      • CorvallisBMW
                        • 13039
                        #371
                        H&R convertible-specific sport springs = teh suck.
                        end of story.
                        • z31maniac
                          • 17566
                          #372
                          My question is whether the HR Race springs will be stiff enough on a 'vert to run an aggressive wheel/tire combo............I have a feeling the answer is no.
                          www.gutenparts.com
                          • CorvallisBMW
                            • 13039
                            #373
                            Yes, they will. Promise :)
                            • TimR
                              • Mar 2008
                              • 549
                              #374
                              Can't read this whole post so yes or no, E30 M3 springs on a Vert.
                              • CorvallisBMW
                                • 13039
                                #375
                                Wishno87 is running that setup currently on his car and seems to like it as far as ride quality goes. It's lower than stock but not nearly as low as aftermarket springs. Maybe he can chime in.
